603,030 active members*
3,689 visitors online*
IndustryArena Forum > Material Technology > Composites, Exotic Metals etc
IndustryArena Forum: Composites, Exotic Metals etc
Page 1 of 9 123
Threads 1 to 20 of 164
Discuss machining Composites, Exotic Metals problems and solutions here.
  1. Book on machining composites / carbon fiber?
    Started by skyways-uav, 11-26-2020 12:24 AM
    book, carbon, composites, fiber, machining
    03-31-2025, 02:36 AM Go to last post
  2. Carbon fibre threading improvements?
    Started by k_turner, 11-23-2022 10:57 AM
    carbon, de-laminate, fibre, machinist, thread
    03-31-2025, 02:34 AM Go to last post
    08-15-2024, 02:02 PM Go to last post
    08-15-2024, 01:55 PM Go to last post
  3. Lightbulb Processing ceramics
    Started by Dekabus, 06-22-2021 10:32 AM
    bottom, hole, pot, problem, week
    06-22-2021, 09:05 PM Go to last post
  4. Question Woodcarving cnc Feeds And Speeds
    Started by grabadosjapansa, 07-10-2005 10:25 PM
    01-25-2021, 08:10 PM Go to last post
  5. How do I cut Water Epoxy?
    Started by jaru-eri, 08-03-2019 03:09 AM
    advisable, epoxy, mill, purpose, speed
    10-13-2020, 12:27 PM Go to last post
  6. CNC trimming Kevlar
    Started by AndyMcB, 12-31-2017 11:55 PM
    cnc, trim, parts, kevlar, year
    05-26-2018, 03:38 AM Go to last post
  7. Milling Carbon fiber Sheets - Need Help
    Started by lopata, 03-22-2018 12:14 PM
    coolant, cutting, dust, problem, water
    05-26-2018, 03:11 AM Go to last post
  8. G10 tooling
    Started by Frankjs, 03-30-2018 03:48 PM
    abrasive, end, g10, mills, test
    05-26-2018, 03:01 AM Go to last post
  9. How to make Carbon fiber sheet ?
    Started by Calico, 06-23-2016 02:24 AM
    carbon, fiber, free, make, sheet
    10-28-2017, 12:00 AM Go to last post
    10-27-2017, 11:49 PM Go to last post
    10-27-2017, 11:39 PM Go to last post
  10. LOOKING FOR TRESPA CUTTING BIT
    Started by jramos187, 10-24-2017 04:58 PM
    000, bit, rpm, sheet, trespa
    10-24-2017, 04:58 PM Go to last post
    10-23-2017, 08:00 PM Go to last post
  11. Corecell GURIT S1800
    Started by waterrat, 05-05-2017 06:16 PM
    chamfer, cnc, gurit, material, s1800
    05-05-2017, 06:16 PM Go to last post
  12. What setup to cut carbon fibre sheet (uk )
    Started by xchipx, 01-15-2009 08:15 PM
    not
    01-06-2017, 02:21 PM Go to last post
  13. Cutting Carbon Fiberon a 3 axis CNC
    Started by Savich, 01-08-2014 03:44 PM
    everyone
    12-21-2016, 11:02 PM Go to last post
  14. Bonding Corian to Corian. What to use?
    Started by mcphill, 01-18-2013 06:48 PM
    available, indicate, then
    08-16-2016, 08:54 AM Go to last post
  15. machining graphite
    Started by davidsutton, 01-16-2008 03:35 PM
    2 Pages
    1 2
    08-10-2016, 04:57 PM Go to last post
Page 1 of 9 123
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
