603,302 active members*
2,888 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion
IndustryArena Forum: Linear and Rotary Motion
Page 1 of 131 1231151101
Threads 1 to 20 of 2609
Discuss ball/Acme screws, R&P, linear slides and theory here.
  1. Sticky Thread Sticky: Ballscrew Basics
    Started by Swede, 03-01-2005 05:06 PM
    8 Pages
    1 2 3 4 5 ... 8
    Yesterday, 03:36 PM Go to last post
  2. Sticky Thread Sticky: Servo or Stepper for CNC?
    Started by CNC_Kid, 02-05-2006 08:37 PM
    4 Pages
    1 2 3 4
    cnc, cutting, plasma, run, servo, wan
    08-06-2021, 02:21 PM Go to last post
    03-16-2021, 08:26 PM Go to last post
  1. linear rail length
    Started by Iron Brew, 06-08-2025 04:34 PM
    06-11-2025, 01:22 AM Go to last post
  2. Dremel horizontal movement
    Started by Lama007, 06-10-2025 03:02 PM
    06-10-2025, 03:02 PM Go to last post
    06-03-2025, 04:09 AM Go to last post
  3. Best belt drive ever! (If I do say so myself)
    Started by Mike Everman, 06-12-2008 11:24 PM
    19 Pages
    1 2 3 4 5 ... 19
    05-27-2025, 01:20 AM Go to last post
  4. Modifying AT pulley to reduce backlash
    Started by v8kid, 04-23-2025 05:24 PM
    backlash, belt, manufacturing, pulley, reduce
    04-23-2025, 05:24 PM Go to last post
  5. Matched angular contact bearings
    Started by slow-poke, 05-23-2024 07:27 PM
    axis, bearings, contact, matched, set
    04-14-2025, 08:59 AM Go to last post
  6. Thk HSR20 rail
    Started by kunte, 10-03-2024 06:11 AM
    04-14-2025, 08:47 AM Go to last post
    04-13-2025, 10:04 PM Go to last post
  7. timing belts
    Started by mrsa, 01-05-2025 04:54 PM
    belts, linear, meshing, rack, timing
    04-08-2025, 04:14 AM Go to last post
  8. Question Retrofitting old press brake
    Started by Rodjams, 04-04-2025 01:41 PM
    gearbox, press brake, retrofit, screw, torque
    04-04-2025, 01:41 PM Go to last post
  9. Exclamation Acme Lead Screw, 1/2"-10 5 start.
    Started by locin, 03-29-2025 12:51 AM
    1/2"-10 5 start, acme lead screw, cnc, gatton
    03-29-2025, 12:51 AM Go to last post
    03-25-2025, 05:34 PM Go to last post
  10. Arrow Taper Roller Bearings VS Angular Contact
    Started by mxtras, 05-19-2005 03:46 AM
    2 Pages
    1 2
    bearings, lead, roller, sigh, taper, work
    03-25-2025, 10:07 AM Go to last post
  11. Ball Screw Bearings
    Started by Texasbowhunter, 03-08-2025 06:14 PM
    ball, bearings, ceramic, range, steel
    03-12-2025, 09:08 AM Go to last post
  12. Question Pulley screw doesn't stay tight
    Started by Lmecano, 02-01-2025 12:56 PM
    02-16-2025, 05:16 PM Go to last post
  13. Ball screws with direct coupling vs pulleys
    Started by javohert, 02-03-2025 07:03 AM
    accuracy, ball, direct, pulleys, run
    02-04-2025, 01:01 AM Go to last post
  14. Should I replace my ACME screw with a ball screw?
    Started by Subcool, 01-29-2025 10:16 AM
    acme, bearings, hiwin, plastic, screw
    01-29-2025, 10:30 PM Go to last post
  15. Linear travel discprency
    Started by nlancaster, 11-25-2024 11:48 PM
    cnc, holes, inches, pair, x-axis
    12-03-2024, 12:00 AM Go to last post
  16. 6040 CNC Linear Guide Rails Upgrade
    Started by tpd123, 11-20-2024 11:52 AM
    carriage, cnc, guide, guides, linear
    11-20-2024, 09:36 PM Go to last post
  17. Who has lifted a 4.5kw Z axis with a Nema 23?
    Started by boydage, 07-13-2020 01:59 AM
    10-26-2024, 09:28 PM Go to last post
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
