603,302 active members*
2,833 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals
IndustryArena Forum: Casting Metals
Page 1 of 17 12311
Threads 1 to 20 of 338
Discuss casting metals here.
  1. Lost Foam Casting Process in Kiev (Ukraine)
    Started by dorosh, 11-01-2013 11:46 AM
    03-22-2024, 10:55 PM Go to last post
  2. Post How to Select CNC Machining Tolerances
    Started by Tikprecision, 11-09-2023 03:34 PM
    11-09-2023, 03:34 PM Go to last post
  3. Induction furnace
    Started by JBV, 09-28-2005 07:50 PM
    16 Pages
    1 2 3 4 5 ... 16
    06-14-2023, 04:26 AM Go to last post
  4. COST ESTIMATION
    Started by mojidravijesh, 03-13-2023 11:56 AM
    03-13-2023, 11:56 AM Go to last post
  5. Red face share aluminum die casting autopart
    Started by tinalulu, 02-03-2016 04:25 AM
    11-15-2022, 03:24 PM Go to last post
  6. New photos from the Lost Foam Process
    Started by dorosh, 05-24-2013 07:23 AM
    08-02-2022, 11:50 AM Go to last post
    04-16-2022, 08:42 AM Go to last post
  7. Lightbulb about Lost Foam Casting
    Started by myrrha, 01-04-2021 04:27 PM
    foam, lfc, lost, lost foam casting, problems
    11-03-2021, 05:23 AM Go to last post
  8. Unhappy Johnson 900 orifice size - stuck, need help.
    Started by 68camino, 07-24-2021 05:53 AM
    09-19-2021, 08:54 PM Go to last post
  9. Alloyavenue forum
    Started by Splint, 05-22-2021 12:18 PM
    forum, long, owner, response, time
    05-23-2021, 05:21 AM Go to last post
    10-21-2020, 09:48 AM Go to last post
  10. Post MF induction melting furnace
    Started by jacky2049, 10-20-2020 04:55 AM
    10-20-2020, 06:25 AM Go to last post
  11. Sinking Deep Casting Aluminium
    Started by Biggermens, 10-06-2020 07:51 PM
    10-07-2020, 10:32 PM Go to last post
  12. Casting Materials
    Started by pmeadow, 08-30-2020 07:49 PM
    casting, ingots, lbs, possibly, weigh
    08-30-2020, 07:49 PM Go to last post
    08-05-2020, 09:14 AM Go to last post
  13. A New Attempt.
    Started by WilDun, 06-23-2020 11:41 PM
    bag, give, good, left, sand
    06-25-2020, 11:00 AM Go to last post
  14. Backyard lost foam aluminium casting
    Started by QUOY, 06-22-2020 12:33 PM
    casting, diy furnace, home foundry, lost foam casting, part
    06-22-2020, 08:51 PM Go to last post
  15. Help with melting 24k gold foil
    Started by WayneOutlaw, 04-01-2020 11:58 PM
    05-05-2020, 10:24 PM Go to last post
  16. Aluminum 7075 home made alloy, possible?
    Started by lukewarm, 08-04-2010 10:39 AM
    home made, not
    11-04-2019, 10:00 PM Go to last post
  17. Casting and rolling of aluminum sheet plate
    Started by Mega_aluminum, 08-09-2018 09:07 AM
    5052 aluminum plate, 6061 aluminum plate, 7075 aluminum plate, aluminum plate, aluminum sheet
    11-04-2019, 09:51 PM Go to last post
Page 1 of 17 12311
Forum Information and Options
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
