603,302 active members*
2,935 visitors online*
IndustryArena Forum: Sharp CNC
Page 1 of 7 123
Threads 1 to 20 of 125
Discuss Sharp CNC machines here.
  1. Help! Y-Axis Faults: Sharp SV-2412 Fanuc Oi-Mate
    Started by roofis27, 08-13-2018 06:58 PM
    card, encoder, servo, sv2412 fanuc axis fault, y-axis
    11-07-2024, 02:45 PM Go to last post
  2. Source for replacement rubber wipers
    Started by DavidHPI, 02-18-2016 03:17 PM
    covers, parts needed, rubber, source, wipers
    01-28-2023, 06:02 PM Go to last post
  3. Won't Home
    Started by jeffm, 06-29-2022 11:39 PM
    11-16-2022, 10:16 PM Go to last post
  4. Over travel Z axis
    Started by dcook1987, 07-24-2013 08:42 PM
    already, since
    12-04-2021, 11:36 AM Go to last post
  5. Machine hang during tool change
    Started by javajesus, 12-01-2007 02:44 AM
    3 Pages
    1 2 3
    goes, next, then, whatever
    07-08-2021, 08:34 PM Go to last post
  6. Tool Changer Manual for Sharp 2412
    Started by MaxWeber, 09-12-2020 05:57 PM
    changer, manual, spindle, thinks, tool
    09-13-2020, 06:45 AM Go to last post
  7. Sharp 2412 spare M code
    Started by cnctsst, 11-16-2011 10:32 PM
    09-12-2020, 05:44 PM Go to last post
  8. Issue with Sv-2412 tool changer
    Started by BuddhaCris69, 03-10-2019 01:58 AM
    change, edit, issue, subprogram, tool
    06-21-2020, 01:29 AM Go to last post
    06-21-2020, 01:27 AM Go to last post
  9. Need computer to machine help
    Started by Larry Myers, 08-17-2008 02:25 PM
    next
    09-11-2019, 09:04 AM Go to last post
  10. Exclamation Looking for Sharp 1640L lathe gears
    Started by Marshall208, 07-25-2019 11:19 PM
    1640l, gears, lathe, sharp, used parts
    07-25-2019, 11:30 PM Go to last post
  11. Looking for a Sharp SV-2412, SV-2517, ...
    Started by rpseguin, 12-23-2018 07:56 AM
    sharp, sharp sv-2412, sharp sv-2517, small footprint vmc, vmc
    12-23-2018, 07:56 AM Go to last post
    12-10-2018, 04:25 AM Go to last post
  12. Siemens 828D control questions?
    Started by Gundawg, 12-07-2018 06:22 PM
    control, date, day, manufacture, siemens
    12-07-2018, 06:22 PM Go to last post
  13. Sharp 1640L Lathe Spindle Problem
    Started by bcavender, 10-09-2018 02:19 PM
    1640l, cams, problem, sharp, spindle
    10-09-2018, 06:45 PM Go to last post
  14. Help! I think I lost all my parameters...
    Started by BuddhaCris69, 06-18-2018 02:08 PM
    09-20-2018, 12:50 AM Go to last post
  15. Question sharp SV-2412 parameters
    Started by Jacobs_Blades, 06-20-2018 10:34 PM
    06-20-2018, 10:34 PM Go to last post
  16. SV 2412 Losing Absolute Zero
    Started by JarrettP, 11-21-2017 08:03 PM
    absolute, losing, machine, origin, stays
    11-21-2017, 08:03 PM Go to last post
  17. Draw bar
    Started by ivanjaramillo, 10-03-2017 02:53 AM
    bar, draw, sharp, sv2412, washers
    10-03-2017, 02:53 AM Go to last post
  18. Question Rigid Tapping not working right.
    Started by DavidHPI, 04-07-2016 02:47 PM
    rigid, sharp sv2412, tap
    07-02-2017, 02:57 AM Go to last post
Page 1 of 7 123
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
