603,304 active members*
Login Register
Merchants ()
Benefit from a wide range of used industrial products.
The search engine for used high-quality machinery and equipment
Browse through the diverse range of our qualified used machines merchants, fast and accurate!
21,000 Used machinery offers Browse categories
The latest offers
ZIMMERMANN SZ 1 V
ZIMMERMANN SZ 1 V
Grinding machines
UNGERER 2100411
UNGERER 2100411
Sheet-straightening machines
LABOR 210
LABOR 210
Precision tool room lathes
KUNZMANN WF 4/3
KUNZMANN WF 4/3
Machining Centers (Vertical)
Travelling column milling machine MECOF CS 500 Agile
Bed milling machines (moving table)
CNC Lathe GILDEMEISTER NEF 400 V3 5. Generation
twin-shaft shredder MOCO AZ11
industrial sewing machine Dohle 751-914
Verpackungs- und Palettierzelle TRANSNOVA-RUF
ZERBST DXP 5
ZERBST DXP 5
WEINBRENNER: TSV 6/3050
Sheet metal gang slitting line
TRUMPF: OMS 450
TRUMPF: OMS 450
TRUMPF: OMS 353
TRUMPF: OMS 353
WALDRICH SIEGEN HCM 2500
Portal & Gantry milling machines
Hankook NSD 750K
Hankook NSD 750K
Spark drilling machines (Small Hole EDM)
Robocut Alpha-1iB
Robocut Alpha-1iB
Wire spark erosion machines
MAZAK INTEGREX i-100S
Boring & Tapping Centers
MAZAK INTEGREX 300-IV S
1 - Skoda CKVJ 2650 AG 3.000 Ton Open Die Forging Press
16 - Forge from 60 to 400 Ton Forging and Annealing Furnaces
A1782
MAE S63 RH SOND
A1782 MAE S63 RH SOND
Presses with mechanical driving
DECKEL-MAHO DMU 60 T
Machining centres
Hängekran 500 kg mit Feinhub
Lifting and hoisting equipment
Rundtisch, RT X
Rundtisch, RT X
Rotary table surface grinders with vertical spindle
Doosan (June 2010) Mynx 7500 Vertical Machining Centre
G&N MPS R - 700 D
G&N MPS R - 700 D
CNC Bettfräsmaschine
Mondiale M 600 CNC
Mondiale M 600 CNC
Other turning Machines
Present your used products now in a target market at an optimal cost / performance ratio!
Merchant account PRIME TRIAL -
Now free of charge!
View tariffs
Used Machinery Agent
Start inquiry
Detail Search
0 hits Filter by your needs!
Categories
Metal working machines 10627 Metal working machines
Woodworking machines 816 Woodworking machines
Plastics, rubber and rubber processing 23 Plastics, rubber and rubber processing
Packaging machines 25 Packaging machines
Food machines 15 Food machines
Beverage technologies 4 Beverage technologies
Textile machines 8 Textile machines
Measuring and test engineering 9 Measuring and test engineering
Construction machines 43 Construction machines
Agricultural machinery 34 Agricultural machinery
Printing machines and paper processing 30 Printing machines and paper processing
Commercial vehicles 280 Commercial vehicles
Conveyor & Drive Technology 4423 Conveyor & Drive Technology
Surface technology 2 Surface technology
Additive Manufacturing 1 Additive Manufacturing
Controls & electronic equipment 4 Controls & electronic equipment
Safety and environment 1 Safety and environment
Robotic and automation 40 Robotic and automation
Others 5272 Others
