579,061 active members*
9,538 visitors online*
IndustryArena Forum: Xylotex
Page 1 of 15 12311
Threads 1 to 20 of 289
Discuss all Xylotex drivers here!
  1. Xylotex 3 axis controller with 269oz motors for sale
    Started by woodworker2, 03-12-2018 01:06 AM
    2 Pages
    1 2
    10-07-2023, 04:46 AM Go to last post
  2. captzman193
    Started by captzman193, 10-30-2020 11:28 PM
    cnc, lights, low, switches, top
    11-13-2022, 12:55 PM Go to last post
  3. Xylotex controller
    Started by cnc Rookie, 06-21-2017 05:01 PM
    axis, mach, running, stepper, xylotex
    11-05-2022, 07:46 PM Go to last post
  4. Stepper Motors
    Started by ironclad246, 03-11-2019 02:49 AM
    inches, mach3, motors, steps, tuning
    10-11-2022, 09:04 PM Go to last post
  5. Stepper Motors
    Started by ironclad246, 03-11-2019 01:22 AM
    10-03-2022, 02:46 AM Go to last post
  6. Xylotex Board quit working !
    Started by kel1, 03-28-2009 07:02 PM
    away, down, took
    11-10-2016, 06:30 AM Go to last post
    10-16-2016, 12:00 AM Go to last post
    03-03-2016, 07:58 PM Go to last post
  7. Xylotex board used in old CNC Shark controller.
    Started by dreiii, 04-25-2015 09:47 PM
    board, cnc, laser, turn, unit
    04-26-2015, 02:52 AM Go to last post
  8. Xylotex 4 axis control box for sale.
    Started by hacker7, 09-29-2014 04:44 AM
    170, 4 axis, 4x4, axis, box, cnc, cnc control, con, control, control box, ebay, for sale, issue, link, router, router table, sale, table, time, wrong, xylotex
    10-01-2014, 05:48 AM Go to last post
  9. Adding estop to Xylotex board
    Started by cgallery, 09-22-2014 03:46 AM
    cnc, cnc router, controller, delay, drive, e-stop, emergency stop, mach, mach3, manual, motion, parallel, parallel port, point, reset, router, screw, stepper, thinking, time, wired, xylotex
    09-29-2014, 12:54 AM Go to last post
  10. Setting VRef on original Xylotex 3-axis board
    Started by cgallery, 09-20-2014 04:42 AM
    09-21-2014, 02:55 AM Go to last post
  11. Xylotex 425 motors with gecko G540?
    Started by StuartC, 05-20-2014 12:35 PM
    08-20-2014, 03:58 PM Go to last post
  12. Motor moves faster and farther in one direction
    Started by momojoey, 07-15-2014 12:35 AM
    board, direction, jogging, mach, mach 3, mach2, make, mechanical, motor, motor shaft, motors, move, one, position, problem, return, shaft, software, star, working, xylotex
    07-15-2014, 12:35 AM Go to last post
  13. New box and limit switches
    Started by clembrant, 03-31-2014 11:18 PM
    add, board, box, break out board, i/o, kit, limit, limit switches, swi
    04-11-2014, 12:11 PM Go to last post
  14. electronics help please
    Started by brent48, 03-25-2014 09:03 AM
    3 axis, axis, board, breakout, breakout board, burn, burnt, cable, cnc, configure, direction, electro, electronics, help please, jog, mach, mach3, motors, move, power, printer, problem, test, xylotex, z axis
    03-25-2014, 09:59 AM Go to last post
  15. replacement power supply
    Started by bartniswonger, 10-16-2013 12:39 PM
    10-18-2013, 02:23 PM Go to last post
  16. Single Axis Problem
    Started by Taflin, 09-11-2013 08:25 PM
    09-11-2013, 08:25 PM Go to last post
    07-28-2013, 04:42 AM Go to last post
  17. Xylotex boards for sale - need repair
    Started by sonosabi, 02-20-2013 02:55 PM
    repair, sale, xylotex
    02-20-2013, 02:55 PM Go to last post
Page 1 of 15 12311
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
