603,304 active members*
2,499 visitors online*
IndustryArena Forum: Metallurgy
Page 1 of 3 123
Threads 1 to 20 of 48
Discuss Metallurgy Here!
    06-18-2024, 11:10 AM Go to last post
  1. Stainless Steel Wedge Wire Screen Tube
    Started by webmesh, 06-18-2024 09:20 AM
    06-18-2024, 09:20 AM Go to last post
    06-18-2024, 09:08 AM Go to last post
  2. high-quality custom-designed wedge wire screens
    Started by webmesh, 06-18-2024 08:56 AM
    06-18-2024, 08:56 AM Go to last post
    02-17-2023, 10:24 AM Go to last post
  3. Engineering materials
    Started by juice01, 09-20-2010 09:03 AM
    08-21-2022, 08:03 PM Go to last post
  4. sheet metal simulation result
    Started by fsa, 09-30-2020 07:17 AM
    09-30-2020, 07:17 AM Go to last post
    09-25-2020, 12:05 AM Go to last post
  5. Ferrous vs Non Ferrous Metals
    Started by FunBuilder, 08-08-2020 10:42 PM
    08-09-2020, 12:52 AM Go to last post
  6. Possible cause for shaft failure?
    Started by Hood, 12-04-2013 12:06 AM
    06-28-2019, 01:47 AM Go to last post
  7. Material spec info
    Started by ChrisW, 11-05-2018 05:24 PM
    material, spec, b265, astm, tapatalk
    11-05-2018, 05:24 PM Go to last post
    10-26-2017, 11:02 AM Go to last post
    09-16-2016, 08:31 PM Go to last post
  8. 303 CRES Bar
    Started by WompasRat, 05-04-2016 03:09 PM
    a582, astm, bar, cres, print
    05-04-2016, 03:09 PM Go to last post
  9. Toolholder material recommendations needed
    Started by patdttr225, 03-05-2016 07:30 PM
    arbor, dia, larger, material, taper
    03-05-2016, 07:30 PM Go to last post
    12-16-2015, 11:27 AM Go to last post
    08-25-2015, 05:37 PM Go to last post
  10. Fractures in AL 6061-T6511
    Started by HRM, 03-12-2015 02:28 AM
    band, fractures, heat, heater, material
    03-12-2015, 02:28 AM Go to last post
  11. stamping 304 stainless steel
    Started by stevethetoolman, 05-05-2014 02:16 PM
    choice, clearance, coating, cpm, cut, cutting, die, help me, problem, punch, sharpen, stainless, stainless steel, stamping, steel, tool, tool steel, tools
    05-05-2014, 02:16 PM Go to last post
  12. Carbide bar question
    Started by Hackandtack, 02-15-2014 11:46 PM
    angular, application, bar, bars, buy, carbide, carbide., corrosion, engineer, find, help me, large, length, locate, machining, made, make, manufacturer, material, minimum, purchasing, question, resistance, shop, tungsten
    02-15-2014, 11:46 PM Go to last post
Page 1 of 3 123
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
