603,302 active members*
2,876 visitors online*
IndustryArena Forum: Mach Lathe
Page 1 of 8 123
Threads 1 to 20 of 157
  1. Recommended Mach3 Turning screenset
    Started by 77_JR, 09-07-2023 03:41 AM
    designs, nice, recommend, screenset, turning
    09-07-2023, 03:41 AM Go to last post
  2. Mach3 Turn Radius Mode not working Properly
    Started by krowncues1, 04-09-2023 01:48 AM
    mach3, mode, move, radius, turn
    04-09-2023, 01:48 AM Go to last post
  3. MACH3 MachTurn not picking up "Index" on mini lathe
    Started by cdowns, 06-03-2022 02:23 PM
    card, gecko, index, pin, spindle
    06-13-2022, 02:31 AM Go to last post
  4. Step/Dir Spindle runs SLOW
    Started by doanwannapickle, 02-13-2022 08:44 PM
    motor, rpm, s/r, set, spindle
    02-14-2022, 07:08 PM Go to last post
    01-21-2022, 01:27 AM Go to last post
    06-20-2021, 06:33 PM Go to last post
  5. change axis
    Started by Paklic, 05-29-2021 09:56 AM
    axis, board, lathe, realize, settings
    05-29-2021, 09:56 AM Go to last post
    03-18-2021, 01:57 AM Go to last post
    01-10-2021, 06:34 PM Go to last post
    11-13-2020, 02:51 PM Go to last post
  6. Mach3 Turn/Lathe
    Started by Cncmachine2, 11-26-2019 03:33 PM
    11-11-2020, 05:11 PM Go to last post
  7. Wachendorf encoder?
    Started by Eagle31, 09-04-2020 04:38 PM
    encoder, mach3, question, thread, wachendorf
    09-04-2020, 06:21 PM Go to last post
  8. Anyone using G76 threading under Mach4
    Started by Dragon8, 06-15-2020 08:38 AM
    area, cut, depth, passes, results
    06-15-2020, 08:38 AM Go to last post
  9. Auto tool changer macro issue
    Started by Handi-andi, 04-09-2020 11:41 PM
    #autotoolchanger, #mach3, #mach3turn, #macro, tool
    04-09-2020, 11:41 PM Go to last post
  10. Master cam post for Mach4
    Started by gabedrummin, 03-12-2020 12:42 PM
    cam, changed, master, post, working
    03-12-2020, 12:42 PM Go to last post
  11. G52 offsets not shown in mach3 screen
    Started by Rimbaldo, 01-25-2020 02:11 PM
    cnc, g52, groove, grooves, mach3
    01-26-2020, 03:51 PM Go to last post
  12. Its all new to me
    Started by BJM737, 01-02-2020 12:42 AM
    01-02-2020, 12:42 AM Go to last post
  13. Spindle indexing
    Started by CS900, 09-14-2017 08:03 PM
    broach, gears, indexing, lathe, spindle
    11-03-2019, 01:07 AM Go to last post
  14. Lathe - Quadature configuration and setup
    Started by bpratl, 09-26-2019 11:35 AM
    display, pokeys, proper, rpm, selecting
    10-20-2019, 01:19 PM Go to last post
  15. STB4100 - Mach3 USB Motion Card question
    Started by ockert, 05-22-2018 11:05 AM
    09-07-2019, 09:01 AM Go to last post
Page 1 of 8 123
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
