602,998 active members*
3,100 visitors online*
IndustryArena Forum: Epoxy Granite
Page 1 of 7 123
Threads 1 to 20 of 138
Discuss Epoxy Granite constructed machines here!
  1. Sticky Thread Sticky: Index to "Epoxy-Granite machine bases" thread
    Started by walter, 06-10-2007 10:38 PM
    12-02-2011, 05:45 AM Go to last post
    01-14-2025, 03:09 AM Go to last post
  1. Vibrating under pressure for density testing
    Started by gmaxwheel, 12-16-2024 11:44 PM
    e.g, mix, posts, size, volume
    12-17-2024, 06:20 AM Go to last post
  2. Epoxy Granite How-To Video
    Started by abender, 05-25-2019 09:32 PM
    epoxy, forum, granite, instructional, video
    09-23-2024, 07:34 PM Go to last post
  3. EG micro
    Started by turpija, 12-10-2014 08:37 PM
    3 Pages
    1 2 3
    aluminum, another, art, build, cause, cnc, construction, cut, design, epoxy, epoxy-granite, except, granite, linear, metal, metal parts, micro, mix, motors, parts, projects, saw, simple, solidworks, star, stuff, upload
    07-31-2024, 02:36 PM Go to last post
  4. Question Is a direct-drive lathe better?
    Started by DeanAustin661, 05-17-2024 09:11 AM
    06-15-2024, 07:42 AM Go to last post
  5. EG type composite for ivory substitute ?
    Started by greybeard, 07-15-2023 06:43 PM
    1mm, experience, ivory, material, scale
    04-27-2024, 08:09 PM Go to last post
  6. Machine base for manual bench mill: epoxy granite vs concrete
    Started by maxki, 04-08-2024 10:45 PM
    2 Pages
    1 2
    04-11-2024, 11:20 PM Go to last post
  7. Epoxy-Granite machine bases (was Polymer concrete frame?)
    Started by walter, 01-09-2007 12:48 AM
    253 Pages
    1 2 3 4 5 ... 253
    02-08-2024, 12:42 AM Go to last post
  8. Analyzing tests
    Started by Vitali-M, 02-09-2021 02:21 AM
    08-23-2023, 12:54 AM Go to last post
  9. Granite surface plates
    Started by AGireland, 07-17-2023 11:35 AM
    07-17-2023, 11:35 AM Go to last post
  10. Avoid ? Epoxy granite for DIY CNC article
    Started by spikee, 09-15-2022 04:42 PM
    cnc, decide, diy, epoxy, granite
    07-15-2023, 03:40 AM Go to last post
  11. Ready mix epoxy granites?
    Started by Cayenne, 10-12-2022 06:53 PM
    07-14-2023, 06:31 AM Go to last post
  12. Filling tubular steel with EG. Pros and Cons?
    Started by Azalin, 08-01-2016 08:37 PM
    06-27-2023, 03:10 AM Go to last post
  13. Mold release + EG + vibration => problems?
    Started by badhabit, 02-12-2021 04:42 PM
    2 Pages
    1 2
    06-25-2023, 02:10 AM Go to last post
  14. Silicon carbide aggregate?
    Started by Fungiblelaser, 05-15-2023 08:11 PM
    06-24-2023, 07:59 AM Go to last post
    05-19-2023, 05:50 AM Go to last post
  15. Epoxy technical chart
    Started by Chmfhm, 03-20-2023 02:08 PM
    03-21-2023, 02:26 AM Go to last post
  16. EG+Hollow section preparation
    Started by stuck, 04-18-2022 09:49 AM
    hollow, inside, section, substance, touch
    03-13-2023, 11:21 PM Go to last post
    01-06-2023, 07:55 AM Go to last post
    09-28-2022, 08:21 AM Go to last post
Page 1 of 7 123
Forum Information and Options
Users Browsing this Forum
There are currently 7 users browsing this forum. (0 members & 7 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
