603,302 active members*
2,878 visitors online*
IndustryArena Forum > MetalWorking > Diemaking / Diecutting
IndustryArena Forum: Diemaking / Diecutting
Page 1 of 8 123
Threads 1 to 20 of 141
Discuss Diemaking and Diecutting here.
  1. How to polish drawing dies after milling?
    Started by Jim27, 11-30-2022 04:45 AM
    05-27-2025, 09:49 AM Go to last post
  2. Moved: Aluminum fixtures advice
    Started by Chrisdeffsheild, 01-27-2025 05:53 PM
  3. cutting edge for 3mm Mild steel sheet
    Started by fsa, 08-28-2023 07:15 AM
    08-28-2023, 07:15 AM Go to last post
  4. Tips for making simple steel rule dies
    Started by leathersmith, 02-07-2007 07:57 PM
    2 Pages
    1 2
    dies, doi, rule, simple, steel, step
    03-06-2023, 04:29 AM Go to last post
    12-13-2022, 03:24 PM Go to last post
  5. HDPE for drawing aluminum sheet?
    Started by Jim27, 06-27-2022 03:57 AM
    aluminum, drawing, hdpe, planning, thick
    11-21-2022, 07:42 PM Go to last post
  6. Shaped sheet metal punch
    Started by Jim27, 01-09-2018 01:31 PM
    2 Pages
    1 2
    06-22-2022, 06:04 PM Go to last post
  7. Die tool used on Lapel pins???
    Started by cyberdine, 01-29-2007 09:20 AM
    01-18-2021, 05:48 AM Go to last post
    09-30-2020, 07:14 AM Go to last post
    07-23-2020, 10:49 AM Go to last post
  8. inserts to machine harden material
    Started by cob, 03-25-2020 06:05 AM
    i.d, inserts, material, open, recommend
    03-25-2020, 07:32 PM Go to last post
  9. Removing feed-thru punch from wood die board?
    Started by iWAYNE, 05-06-2019 08:07 PM
    05-07-2019, 11:02 PM Go to last post
  10. Tripping Breaker on New Clicker Press
    Started by iWAYNE, 07-29-2018 03:57 PM
    3 Pages
    1 2 3
    07-31-2018, 09:08 PM Go to last post
    04-09-2018, 03:31 PM Go to last post
  11. toughest steel
    Started by cob, 04-03-2018 05:23 AM
    appreciated, steel, strong, thinking, toughest
    04-04-2018, 01:48 AM Go to last post
  12. Brass Tubing Into a Cone - Die Metal Type?
    Started by jesset, 02-25-2018 09:45 PM
    brass, forum, make, metal, tubing
    02-26-2018, 11:54 PM Go to last post
    02-25-2018, 10:28 PM Go to last post
  13. Machining accurate pockets and features
    Started by Jim27, 12-29-2017 04:45 AM
    cnc, cut, size, suggested, test
    12-31-2017, 04:40 PM Go to last post
  14. Making a radius punch and die
    Started by Jim27, 12-27-2016 05:18 AM
    3 Pages
    1 2 3
    12-24-2017, 04:43 AM Go to last post
  15. Dowel pins for punching small holes?
    Started by Jim27, 12-09-2017 04:19 PM
    dowel, holes, milling, pins, side
    12-21-2017, 02:17 AM Go to last post
Page 1 of 8 123
Forum Information and Options
Users Browsing this Forum
There are currently 4 users browsing this forum. (0 members & 4 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
