Hello
I am trying to control HRT-210 indexer with control box via serial port. I want to use indexer independet, without CNC-machine. I am using program named Terminal, downloaded from here:
velenje.cx - Velenje Resources and Information. This website is for sale!
Cable has made as Haas manual instructions. DB9 to DB25 1to1,2to2 and so on. Haas manual from here:
http://www.haascnc.com/pdf/96-0315.pdf
Indexer parameter has set as follows:
Param21=1
Param26=3
Param33=0
Terminalprogram settings are as follows: 1200, 7 data, even parity, 2 stop, Handshaking none. Computer is laptop with USB to serial converter.
When i ask command UP (U axis,
servo position)and hit send tab nothing happens. Same with other commands. If i connect loopback plug to DB9 connector i will get all back what i have wrote, so Terminal program works. What i am doing wrong.
Vekku
