Casting Steel
Steel in the molten state is very hungry for gases; oxygen and nitrogen get sucked up quickly and end up in the casting. There are some alloys added to the molten steel prior to casting to "tie up" the gases so that the castings do not look like swiss cheese (aluminum for the oxygen and zirconium or titanium for the nitrogen). These alloys are added just prior to pouring, and they will chill the metal when added, so you have to superheat which makes everything more reactive. After you have taken care of the gases absorbed when melting, you then have to deal with the gases absorbed while pouring into the sand mold and then liberated by what ever binder that you are using. Add to that the fact that molten steel shrinks during solidification where your casting yield is about 50% or less of your pour weight. Also depending upon the binder used in your sand mold, steel will react with the sand and becomes burned onto the casting. In short and to wit you have major obstacles to overcome with your idea if you want decent castings. If it were easy everyone could do it.
Andrew Abrams
Marcellus Metalcasters, Inc.
