Originally Posted by
double a-ron
Not only does it work but, if you have a small machine like I do (a Haas mini mill 2, with a 7 peak hp spindle) then it is a must. You program for best case scenario, like a straight line cut. The toolpath constantly adjusts feedrate and stepover to keep the spindle at full load. Not 40% then spikes at 200% then back to 40%. I keep my spindle loaded at 125% at all times. I wring every last kw out of it. And believe it or not its easier on the tool and the machine. Spikes hurt. Also, my tool life has gone through the roof. I run full depth all the time so I am always getting the most out of my end mills.
Total cost to upgrade to volumill was rather expensive. Haas got 2500 to turn on HSM and gibbs got 2800 for the volumill solids modual. Paid for it with two jobs I wouldn't even cosidered taking in if I didn't have it.
I guess I always try to buy a tool first then get into the market that requires it. Did that with the mill, lathe and software. It's hard to get into a new area and quote work if you don't have the right tools. Next up is solid surfacer and the mold industry. I'm dying to try my hand at mold making.
