587,541 active members*
4,137 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Radius problems when generating gcode from bobcad for mach3... ?
Results 1 to 8 of 8
    Oct 2006
    33
    Hey guys, we're having some radius issues when generating gcode from bobcad... bobcad seems to generate its IJ in incremental mode and sometimes will get a 0 arc I ... and mach 3 doesnt like that at all. Why is bobcad doing that ?
    is there a way you can set bobcad to generate absolute IJ ? would that fix it ?
    Also, what are IJ exactly ? how do they work ? I notice and understand the x y and z.. but what do i and j have to do with anything ?
    sorry, realllll newbie...
    Thanks !
    Scy
    Dec 2006
    43
    Having same problems.... I and J codes are for arcs, your G02 and G03 commands. See if you can use a different postprocesor to use the R code for arcs. I am still learning also and am looking at tayloring the postprocessor to meet that need.
    Jan 2005
    71
    Cool I and J as well as K values
    These are generally used to describe the centerpoint of a radius. Usually it is incremental from the startpoint. Lets say your arc center is 5 in X an 5 in Y. Your start is at X1 and Y2 your I would be 4 and your J would be 3.
    Jan 2006
    4396
    Quote Originally Posted by scyan View Post
    Thanks !
    Scy
    Quote Originally Posted by bigj121 View Post
    To add to what Gandalf said. Have you tried to setup BCC to Program using "R" instead of I and J?
    Also I, J, K are relative to X(I) Y(J) Z(K) respectively.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Aug 2003
    449
    Ultimately you have two options.
    1. Configure Mach3 to accept incremental I and J.
    2. Configure BobCAD to Output absolute I and J.
    For option 1, I can't provide all that much help because I haven't so much as looked at Mach3 for quite a few months. I do know however that you can change the way Mach3 accepts arcs...maybe in the Config menu?
    For option 2, Open the NC-CAM window. Go to 'Setup' and Click on 'Driver'. Next click on the 'ISO' tab. Just uncheck all of the options for circular motion and then Click OK. You will be outputting abs I and J in no time.
    Regards
    Mar 2003
    35538
    You need a post from BobCAD that won't output arcs with zero radius. If absolute arcs have a 0 radius, they won't work either.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2006
    33
    What do you mean by a post from bobcad ? I dont understand what you mean... you mean in my driver ?
    Thx all, i have some stuff to tinker now.. hehe
    Mar 2003
    35538
    Post processor that you use to create the g-code.
    http://www.bobcad.com/index.php?sele...lic_html/posts
    Gerry
