587,541 active members*
3,819 visitors online*
Results 1 to 12 of 12
    Jan 2011
    RFQ Turned 6061 Parts
    Hey guys!
    I just need a small run of these parts please.
    I would like two quotes for each part please.
    One for 30 qty and one for 60 on the part labeled "bracket spacer".
    The other one labeled "CAS insert" needs to be for 10 and 20 qty.
    Both need to be in 6061 T6 Al.
    As for the finish, after I receive these parts they will be tumbled and anodized before assembly.
    I'm looking to put this order in asap too.
    Please email ([email protected]) or message me with quotes or questions.
    Thanks!
    Jason
    Attached Files Attached Files
    Jan 2011
    For those that don't do DWG, here is PDF.
    Hi, when do you need the parts by?
    Sam
    cncspec.com
    Jan 2011
    If they could be completed with a week or two would be optimal.
    Aug 2010
    128
    Is there a missing spec on the CAS insert? Groove diameter?
    Jan 2011
    Yesir, you are correct.. you're actually the first to notice. I apparently didnt transfer everything and the only excuse I have is when I made the file/started this thread... (notice the time.. haha)
    Anyway the Diameter of the groove is 1.380 inches. I'll update the files soon to reflect.
    Jan 2011
    Fixed.
    Aug 2010
    128
    Are you adding two additional spacers to the job? If so, how many of each are needed?
    Jan 2011
    Disregard those last two files.
    Hi Jason,
    I have time, is the job still open?
    Thanks,
    Sam
    CNCspec.com
    Jan 2011
    Jobs were filled, Thanks to all those who quoted.
    Jason
    Jacksonqin0305 Guest
    Re: RFQ Turned 6061 Parts
    Hi,this is Jackson, mechanical manufacturing engineer with extensive field knowledge and work experience and my factory located in the world manufacture base center Dongguan/Shenzhen,China,
    we offer Lathe and Milling/sheet metal fab/parts stamping service, any new works,
    Just contact me,[email protected] / whatsapp+86 13532883201
  1. First Turned Parts on SlantPro
    By menzzer37 in forum Tormach Slant Lathe
    Last Post: 07-11-2015, 04:35 PM
  2. Need some brass parts turned RFQ
    By msloan in forum RFQ (Request for Quote)
    Last Post: 01-02-2012, 05:26 AM
  3. RFQ on Aluminium turned parts
    By DesignRR in forum Employment Opportunity
    Last Post: 02-14-2011, 07:13 PM
  4. RFQ on turned steel parts
    By TheGreenMachine in forum Employment Opportunity
    Last Post: 11-12-2010, 07:15 PM
  5. RFQ - turned parts
    By Runner4404spd in forum Employment Opportunity
    Last Post: 11-01-2006, 04:57 AM
