I need 2 of this gantry. Holes must be accurate so my linear bearings can rid on the rail. Email or PM your quote.
Edit: I need it in aluminum 6061
thank you
CNC2k
thank you
CNC2k
Woops, that was supposed to be a private quote![]()
Anyone?
What material is it?
What are the tolerances of the outer dimensions?
Obviously the tapped bottom needs machined to cleanup but are the other thre sides machined or can they be left flame cut or saw cut?
www.integratedmechanical.ca
i not sure what you asking, Here are some pictures what i looking for.
Material would be - aluminum/ oak/ PVC/ Steel -what is your spec?Originally Posted by DareBee
If the outside edges of the part are free air then they dont need to be machined unless you want it done for appearance, this means the parts cost less to produce; also if the tolerance on the outer edges are +/-0.001 it would have to be machined as my saw and tape measure would be +/-0.030.
are you still looking?Originally Posted by cnc2k
