587,204 active members*
3,095 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > How to Run a Large Stepper On A Small Board without frying
Results 1 to 9 of 9
    Mar 2004
    500
    Hi all,
    I was thinking of buying some Gecko G201's for my first router, and buying brand new motors and making a small machine at first. I figured that way, I wouldn't have to move from a small system to a big system and by new drivers and steppers. But then I thought of just getting a cheap kit and gettting some good motors, ( again so if and maybe when I move up I don't have to buy twice). I was looking at the Hobby CNC 4 axis driver for about $60 for four axis. I want to buy some 190 oz-in vexta motors for this. They are rated at 3 amps and 3 volts. The board is rated at about 1.25 amps per phase continuous and 1.5 amps at startup ( just wondering, what's that mean?). So my problem is, how to run these motors at 1.25 amps or whatever. How much torque would I lose by running these motors on this driver? Would there be any other problems like overheating, or lost accuracy?
    Thank you very much for your time.
    I really appreciate it. :rainfro:
    Mar 2003
    35538
    They should run fine, but you'll lose about 2/3 of your torque. You might want to look at the drivers here:
    http://www.embeddedtronics.com/
    A little more money, but you may not need to get Geckos in the future. Or, you could buy 190 oz motors that only use 1 amp or so. I saw them on the Oriental Motor site.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2004
    500
    Where do you get the parts for those boards?
    Thanks.
    Mar 2004
    500
    Also, how much do you figure the cost of these would work out to, I mean the single axis ones for one.
    Thanks.
    Mar 2004
    500
    Hello?
    Mar 2003
    35538
    He's got parts lists with part numbers for Digi-Key. http://www.digikey.com
    Gerry
    Mar 2004
    500
    What's the cost work out to total after all of the parts are ordered?
    Thanks.
    Mar 2003
    35538
    You'll have to figure that out yourself. I have no idea.
    Gerry
    Mar 2004
    500
    Oh, just wondering from someone who else has had expierience with making these boards. I figured it out, and I'm not sure If I can say on this post.
    Thanks.
  1. Unipolar Stepper run with Bipolar Driver
    By bcromwell in forum CNC Machine Related Electronics
    Last Post: 06-21-2013, 03:20 PM
  2. Looking for controller board for synchronized stepper motors
    By Yellowbeard in forum CNC Machine Related Electronics
    Last Post: 04-02-2005, 03:50 PM
  3. Replies: 8
    Last Post: 01-26-2005, 02:10 PM
  4. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
