603,365 active members*
2,988 visitors online*
Results 1 to 8 of 8
    Feb 2006
    12
    loading programs into dos
    I Am Setting Up A Hurco Kmb1 Mill It Currently Has A Computer Running Dos That Will Only Read Prt Files But Want To Be Able To Load Nc, Txt, Tap Format Files In The Control Panel Of The Machine I Have 4 Boards On Top An 7 Boards On The Bottom All Are The Same Can Any One Give Me Any Input In The Direction I Need To Go To Achieve My Goal Here.
    Mar 2003
    928
    Bkstout,
    I moved this here for more exposure..
    Moderator
    Mar 2003
    4826
    Well DOS only likes 8 character file names, and up to 3 character filename extensions, but other than that, you should be able to change the extension from nc or tap to prt. You can do this on your windows computer, or you can do it the hard way, by using the REN command in DOS, at the command line.
    However, you would still need to format the code in the file to match whatever Hurco requires for gcode or conversational, or whatever.
    There, that is 2 cents worth
    First you get good, then you get fast. Then grouchiness sets in.
    Feb 2006
    12
    anyone got any ideas where i can find the ren cammands for dos or have any other ideas that might help me out
    Nov 2005
    12
    Im not sure of the meaning of your question, but:
    move fileA fileB
    will rename the file "fileA" to "fileB", but the command is normaly used to move the file to an other directory:
    move [path]fileA [path]fileB
    Regards,
    Hugo
    Dec 2003
    24260
    Some DOS commands are embedded in the DOS system, there are some are separate utilities, usually loaded in the DOS directory, for info on DOS commands look at http://www.computerhope.com/msdos.htm
    Al.
    Albert E.
    Feb 2006
    12
    thanks for all the comments i am heading in the right direction now!!!!
    Dec 2005
    3319
    If you use DOSSHELL (free gui that comes with DOS 5 and up), the rename process is done much like it is done in Windows but with the 8.3 character limit proviso.
    If you have DOS 6, simply type HELP from the C:\ prompt. Look for RENAME (REN) command and follow the directions.
