588,574 active members*
12,377 visitors online*
Results 1 to 2 of 2
    Apr 2020
    MAHO Error Z 07 Z 02 HELP
    We have two Philips CNC MAHO 700 S machines. One of them knocks out an error Z 02 Z 07 with uncontrollable jerk forwards or backwards. The error occurs within 1-3 hours of the beginning of the business day. Then after the first time the error occurs earlier. From the another MAHO machine we change the motor, drive and board of the Z axis were changed to MAHO with erorr. The error did not go away. Visual inspection did not help. Help what it can be?
    Oct 2018
    11
    Re: MAHO Error Z 07 Z 02 HELP
    Hi Garmata, check the measuring system as this is the cause of the Z02 alarm
    All the best
    Nov 2023
    Hi, garmata, We are also dealing with such a problem. Did you manage to find a solution for your car? Thank you for your help
