588,464 active members*
7,550 visitors online*
Results 1 to 6 of 6
    Mar 2013
    8
    CNC in Garage
    I've purchased a Fireball Comet, live in north Texas, and want to know if there would be any problems associated with having the computer that runs the router in the garage.
    Aug 2012
    621
    Dust and heat will be your main issues. The comet is small enough to consider putting it into an enclosure. That would be my first choice. CNC routers raise an incredible level of dust, and your garage will otherwise soon be coated everywhere.
    If enclosing the router is not possible, then the computer case needs to be protected seperately. An enclosure with a big A/C filter and an exhause fan is best. The computer needs airflow for cooling, but dust will settle inside the case and act as a thermal blanket, if not filtered out, eventually killing the electronics.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Dec 2003
    24221
    When using fans for cooling, it is generally better to implement filtered positive pressure enclosure.
    IOW, place a filter on all incoming Fan cooling.
    In this case fans should not be expelling air.
    Al.
    Albert E.
    Mar 2013
    8
    Thanks guys, I'll enclose the router with the exhaust as recommended. I appreciate the help.
    More later,
    Casey
    May 2022
    9
    Re: CNC in Garage
    For the dust-in-computer problem, you could consider placing the entire computer in a big, fully sealed metal casing. The fans of the computer distribute the heat evenly in the inside of the casing. The metal casing can transfer the heat to the surrounding, dusty air.
    Ah, I see I'm replying to a 9 year old discussion. I hope somebody can still benefit from it.
    May 2024
    Re: CNC in Garage
    Saxenda (liraglutide) is a prescription medication primarily used for weight management in individuals with obesity or overweight conditions. It works by mimicking a hormone that regulates appetite, helping patients feel fuller for longer periods. Administered as a daily injection, Saxenda (liraglutide) supports weight loss by reducing food intake and promoting a feeling of satiety. Clinical studies have shown its effectiveness in achieving significant weight loss when combined with a balanced diet and regular physical activity. However, it's essential for users to be aware of potential side effects, such as nausea or low blood sugar, and to consult their healthcare provider to determine if Saxenda (liraglutide) is suitable for their weight management plan.
  1. can I run a T-42 in my garage?
    By MDSpencer in forum Hardinge Lathes
    Last Post: 07-10-2012, 02:35 PM
  2. VMC 15 XT fit in garage?
    By Hellpit in forum Fadal
    Last Post: 08-13-2009, 11:27 PM
  3. What's in this Garage..??
    By Ridgeback in forum Bridgeport / Hardinge Mills
    Last Post: 10-22-2008, 05:18 AM
