587,999 active members*
2,683 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > How to get the firmware from a MR-J2S-B servo amplifier?
Results 1 to 14 of 14
    Mar 2012
    I have several bad MR-J2S-B servo amplifers and I do not really want to give up them. I judge the trouble reason is that the firmware of main controller---SH7065 had been lost. Fortunately, I have some good amplifers in hand with the same model. Can I get the firmware from a good one and re-programme those bad? or where can I downlaod the firmware I need?
    Please help!
    Thanks and Regards,
    greatwall2
    you can reflash them with SHflash.exe utility which comes with SETUP161E. when it asks to set the boot mode short pins 5-6 of the CON6 connector and switch on the power. the 7-seg LED display should stay blank. PM me with you email and i will send you a firmware image.
    Mar 2012
    Quote Originally Posted by dm1try View Post
    Thanks a lot. My mail address has been sent to you by PM and I expect your reply.
    Regards,
    greatwall2
    Dec 2018
    3
    Re: How to get the firmware from a MR-J2S-B servo amplifier?
    How can use SHflash.exe to chang firmware?
    see message #2. why do you want to do it?
    Dec 2018
    3
    Hello, sir.
    I am come from Taiwan
    Some things need your help
    My company's machine J2S drive has been discontinued
    MR-J2S-350A-s011 ( Firmware BCD-B26W005 A1)
    but i only can buy MR-J2S-350A( Firmware BCD-B26W005 B6)
    and now My company's machine have trouble can't work need to change driver
    I saw that it can used SH-DSP Flash rom and SHflash?but i don't know how to use this
    Can you teach me how to change Firmware? please
    aha, i see.
    it is possible to do if:
    1. you have a working MR-J2S-350A-S011 drive to read the firmware from.
    2. your standard MR-J2S-350A has a FLASH CPU. see http://yurtaev.com/mr-j-faq.html
    drop me an email at the above link, i will send you a utility which can read the firmware. you'll need a windows pc with MR-CPCATCBL serial cable (the same used for MR Configurator)
    if the firmware can be read, i will convert it fo intel hex format which can be used with SHFlash utility to flash the new drive
    also, you need to read all 255 parameters from the -S011 drive using MR Configurator. to do it, set param No.19 to "ABCD", reboot the drive, read params and save em to a file
    Dec 2018
    3
    Thank you very much for your reply.
    I have read this article before, but I don't know how to operate the process.
    I will read correctly about the parameters.
    But can you tell me the correct read firmware process?
    And how to write the firmware process correctly?
    You are my savior
    my E-mail was collinslin6478@gmail-com
    Sep 2007
    31
    Quote Originally Posted by dm17ry View Post
    aha, i see.
    Hi i have the same problem with MR-J2S-100A-S046
    How can i read the old firmware?
    May 2020
    aha, i see.
    Hello sir,
    I have the same problem with MR-J2S-70B.
    I need to unload firmware and parameters from the old and load it to the new servo amplifier.
    Is it possible that another firmware version in the same servo amplifier won´t work with CPU controller correctly?
    Thank you
    Apr 2022
    Thanks for Support!
    I sent you email about MR-J2-40A
    Feb 2024
    Quote Originally Posted by M7MDBUZZ View Post
    Thanks for Support!
    Hello my friend Please send me the mr-j2sa and mr-j2sb boot and firmware file. Thank you
    [email protected]
    Feb 2024
    [email protected]
    Please help me use this software SHflash.exe user
    [email protected]
  1. POSSIBLE SERVO AMPLIFIER ISSUES
    By BornToWin in forum Fanuc
    Last Post: 09-12-2013, 01:57 AM
  2. Servo Amplifier FANUC
    By Antonio Arguijo in forum Fanuc
    Last Post: 12-07-2010, 03:53 AM
  3. servo amplifier
    By markjb in forum Fadal
    Last Post: 06-25-2009, 02:56 PM
  4. servo amplifier
    By frankg521 in forum Servo Motors / Drives
    Last Post: 07-20-2007, 01:29 PM
  5. Servo drive / Servo Amplifier
    By Ken_Shea in forum Servo Motors / Drives
    Last Post: 07-10-2007, 11:12 PM
