a while ago i started working on code layouts
different formats between easy to read, or dense
at some point is easy to do things how you like, rather then hunting down for functionalities through other softwares![]()
That is the reason i started Devellopment of E++. i wanted the Syntax Coloring and Indentation like i have in Notepad++, but without all the extra functions you don't need.. and some extra's for G-Code specifically For EdingCNC..
That is why the Parameters have colours depending on their status.. a Volatile Parameter is green, a Non Volatile Parameter is Orange, and a System Parameter is Red..
I need to do some more Coding, as the Parameters #1 through #26 represent the letters of the Alphabet, #1=A, ...#26 is Z, to Enable one to use these in Self written Custom M-codes..
That is why, and how i came up with Codes like M34 A45 R30, a Polar Coordinate meaning "From Circle Center, move to Radius 20 @45°, and it works a treat!
I am just getting started on EdingCNC, with a CNC720. I am definitely not an amateur, since I am - as of this year - a former professional machinist now in engineering school. I am happy to learn all about what I can do with my CNC720, but it was a MF-ing hassle just to connect Teknic Clearpath DC servos to this controller. Plus, the default limits and other things I would have to discover on my own were just nonsensical. I have since figured a lot of these things out, but it feels ridiculous that I have a professional CNC career behind me and I couldn't even jog the machine.
If you're writing new manuals, and you have Eding's ear, you might consider pushing them to publish a "getting started" FAQ. There are still many steps that have to be cleared before I can move on to using the machine, like squaring the tandem axes that isn't covered anywhere I can find. Through tenacity, I was able to connect a bunch of dots and make homing work with Tandem axes, but that's only half the battle - and it's not really even solved. Tandem axis homing often ends with one inductive switch in the open condition the other in the closed condition, with absolutely no idea what to do about it.
There are other, philosophical questions that I would like addressed too. Like, for example, why homing the machine zeroes the work coordinates. WTF?
Your 14-year-old video clearly shows that EdingCNC is capable, which is what makes this so frustrating.
No.. it doesn't...it sets the machine Coordinates...and not necessarily to zero.. it sets the coordinates to the value that you have put in the Setup..There are other, philosophical questions that I would like addressed too. Like, for example, why homing the machine zeroes the work coordinates. WTF?
on my Mil, it does home the machine at X0, Y0, Z0, A0, but on my Lathe it homes at X53.5, Z295 (It's an EMCO Compact 5 CNC, with EdingCNC)
DId you mix up F2 and F3?..
Sorry for the Off topic comment. Arie Im looking for the heidenhain te425 matrix pinout you mentioned before in a post. Wondering if you would share it? Thanks
Sure thing.. Here Goes..
P20 P21 P22 P23 P24 P25 P26 P27 P1 END ± 3 6 9 ENT MANUAL HAND WHEEL P2 N/U 0 2 5 8 NO ENT MDI MOD P3 Q . 1 4 7 REF SINGLE BLOCK GRAPHIC P4 TOUCH PROBE IV Z Y X DEL PGR P P5 RR LBC STP C EXT CE EDIT I P6 RL LBS N/U CC PGM CALL LEFT DOWN P7 TOOL CALL CYCLE CALL RND CR CL PGM GOTO P8 TOOL DEF CYCLE DEF CT L PGM NAME UP RIGHT P9 APPR DEP N/U N/U CHF V N/U P17 ! # " Q Ctrl A SPACE Z P18 $ % W E S D X C P19 ^ & R T F G V B P28 * ( Y U H J N M P29 ) _ I O K L , . P30 P31 + = P < ; > ? / P32 BACK RET : SPACE
