603,311 active members*
1,627 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Hundreds of Mill and Lathe post processors for CAMWorks
Results 1 to 8 of 8
    Nov 2012
    Hey guys -
    I was cleaning up my files, and I came across this gem. I've zipped up all the post processors I found on my computer, and I want to share them with you.
    https://www.dropbox.com/s/hsdyb6tqwp...posts.zip?dl=0
    There's several hundred mill and lathe post processors archived here in various formats and legibility. The source files are also sometimes included with the posts, so they are sometimes editable.
    Lots of Haas and FANUC-style controllers, a bunch of Okumas, Fadals, and a few in between. The ZIP archive has a list of the posts included therein.
    I have some mill-turn post processors, but I don't believe they work with modern versions of CAMWorks because of the way the WCS has been flipped in the past few versions, but you never know.
    If anyone needs help with CAMWorks post processors, let me know.
    info (at) blacksunengineering (dot) com
    Dec 2015
    7
    Re: Hundreds of Mill and Lathe post processors for CAMWorks
    Quote Originally Posted by coyoinu View Post
    Hey guys -
    I need a post processor for my Fadal to be used in Camworks 2015..............Just got camworks, so I am not totally certain what I need, but I know the default post is not letting thr machine run correctly.
    Jazper
    May 2015
    Thanks for the posts... Need a little help
    I am trying to get a grip on 5 axis milling. I'm able to get my tool paths after weeks of experimenting. They look good in Virtual machine using APT-CL. When using G-code Z value is way off. Using the post supplied with CW Z is up in space all other axis look ok. Using the 5 axis Haas post that you supplied Z crashes into part. I don't work in the machining industry anymore but I haven't lost interest in the cad cam stuff. Now that I'm not in this business anymore, I am starting to rediscover my love for it as long as it's from a distance. Currently using CW 2016 with SW 2016. Could you offer any advice as to what I need to modify or do differently in my post or machine setup. Not many helpful tutorials online that I have access to. Thanks for any help.
    Apr 2016
    Thank you very much, I hope and they are useful, I program an okuma with mastercam and I want to learn camworks.
    sorry for my english. But thank you again
    Mar 2010
    18
    HI coyoinu
    Y recently buy Miyano cnc lathe with Fanuc 0-Mate TC control unit from 1995 year.But y don t have a post processor to make some program.Y work in mastercam software.Can you somehow help me to make this machine online.This is my first cnc machine....
    Apr 2018
    5
    hi i need a post processoer for a fanuc ota colchester cnc2000l lathe i can find one in your list, i have downloaded and installed dropbox as prompted but cant open file,how do i do this,or can you just email the single file over thanks neil it keeps saying the files can not be previewed
    Jan 2017
    Hello
    i need a help with CAM works post processing even if your offer is actual.
    Jan 2021
    Hey guys -
    Hello . Can you give info about version of this cam works ?
  1. Help Needed! Haas Mill Mill 2 Post Processor for Camworks
    By brettwemyss in forum Post Processor Files
    Last Post: 07-12-2012, 02:55 AM
  2. Camworks post for Haas hl4 lathe
    By bruiserba in forum CamWorks
    Last Post: 01-07-2011, 05:07 PM
  3. Haas Lathe Post for Camworks?
    By DomB in forum CamWorks
    Last Post: 06-14-2010, 11:31 PM
  4. Mach 3 Lathe post processors
    By Biggermens in forum BobCad-Cam
    Last Post: 04-20-2007, 01:18 AM
