603,314 active members*
1,878 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA LU15 OSP7000L 1377 ALARM Door open close answer Error
Results 1 to 8 of 8
    Nov 2022
    11
    Hello Everyone,
    We have a OKUMA LU15 Machine. We have a problem. There is an error. It is "1377 ALARM Door Open Close Answer". When we turn off and turn on machine, normally we could open the door in the past. Now we can't open the door. When the door is closed, There is CCC1C signal but there is no DRCL signal. When I push Close button, DRCL is on, and after about 10 second there is the error 1377 ALARM. When I try to open the door with Push button, I can open it. DOOR INTERLOCK Key is 0 position. I attached some photos for our machine. What can i do? I'm waiting for your help. Thank you.
    Re: OKUMA LU15 OSP7000L 1377 ALARM Door open close answer Error
    Quote Originally Posted by onurzc View Post
    Hello Everyone,
    The Door Close Sensor might be broken, need to replace with a new one.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Nov 2022
    11
    Quote Originally Posted by cncmakers001 View Post
    Thank you for answer. We checked the Door Close switch, It looks good. But there may be problem on IO cards or relay.
    Aug 2011
    459
    You can check I/O status of all switches or sensors in the CHECK DATA pages
    "Imagination is more important than knowledge."
    May 2011
    11
    HELLO I CAN SOLVE YOUR PROBLEM PLEASE PM ME
    Dec 2005
    619
    Quote Originally Posted by piston_90 View Post
    Ask it here, answer it here. That's what this forum is for, to get the information out to anybody that needs it, not to hide it in a PM.
    Mark
    Nov 2022
    11
    Hello everyone,
    We fixed the problem. In the past, We used different floppy disk so we saw different error and signals. Then We uploaded the original machine disk. Then We changed door switch too. Everything looks good. Thank you so much for everyone.
    Nov 2011
    478
    The OKUMA LU15 machine tool error "1377 ALARM Door Open Close Answer" you described is usually caused by the door lock system failing to receive the correct feedback signal within the set time. Judging from the signal situation you provided, the problem may be caused by a door lock sensor failure, mechanical stagnation, loose feedback signal line, or abnormal input module. It is recommended to check the relevant signal changes through the I/O screen to confirm whether there is a feedback signal after the door is closed; at the same time, check whether the door lock mechanism is misaligned or worn. If necessary, you can temporarily test the jumper under the supervision of a technician, but it is not recommended to bypass the door lock system for a long time. If it still cannot be resolved, it is recommended to contact Okuma official technical support to further troubleshoot the PLC ladder diagram or parameter setting problems.
    https://www.elephant-cnc.com/
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
  1. Replies: 1
    Last Post: 01-07-2021, 09:05 AM
  2. Have to open and close door to run next program.
    By coop31 in forum Cincinnati CNC
    Last Post: 11-11-2020, 01:51 PM
  3. Replies: 16
    Last Post: 06-12-2020, 03:18 AM
  4. stopping program and opening door OKUMA OSP7000L
    By Havemann7174 in forum Okuma
    Last Post: 01-23-2014, 02:15 PM
  5. Verify door close and open on Fanuc 21 t
    By gtrrpa in forum Fanuc
    Last Post: 08-19-2010, 04:38 PM
