Hello,
I am trying to engrave text for the first time and am having alot of trouble.
I tried just putting text on the face of a cube, but it goes on upside down everytime. The 'flip vertical' buttons are greyed out so I cannot use.
With it upside down, the rotate feature does not work, I put in a 180 degree rotate after defining the rotate point, but nothing happens.
I also cannot use the smart dimension tool to position it exactly where I want, it will not let me select the text at all, not even if I 'edit sketch'.
I created an open, horizontal line on the face and got the text to stick to it using the 'curves' feature in the text menu... this way the text is aligned properly, but then I cannot extrude it or make toolpaths.
What am I missing?
