587,998 active members*
1,884 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Fairbanks-Morse opposed piston engine scale build
    Jan 2007
    12
    As the title suggests, I am toying with the idea of doing one.
    I got this idea shortly after having been invited to help a power plant mechanic overhaul one sometime in the fall. I have been wanting to own one of those engines, but two things put a stop to this: the size of the engine, and the fact that one of these would set me back $11ty thousand.
    I have never built an engine but am fully aware of the complexity, especialky when I consider a 12cyl version. Turn two crankshafts, two cams which drive the injectors, turn 12 cylinders ans 24 pistons... You get the idea. I also considered using some commonly available parts but the purist in me says "make it all".
    What I am wondering is if I contact Fairbanks-Morse for the blueprints and tell them my intent to scale down, would they be all for it or would I run into legal issues because technically I would be copying their design, albeit at a smaer size scale.
    AC-130U
    Dec 2006
    603
    I think if you want to take on something like that it would be great. I know a fellow who is doing a single cylinder with 2 pistons. I'm sure it can be done. Go for it.
    Oct 2006
    708
    Can't hurt to ask the parent company. Otherwise design your own based on available manufacturing technology and factors such as available screws - you can make the screws too, if you want to spend 12 years building the engine...
    Meanwhile, you can look at these dual pistol 2 stroke diesel engines for inspiration:
    News - Achates Power
    Jan 2007
    12
    Right, fasteners and such I will use off the shelf. I was talking about major parts like pistons, conrods, etc. Would I use those off the shelf? Maybe, not sure yet.
    Then there's the crankshafts and camshafts. I dunno who would be able to make those for a 12cyl version of the scale model.
    AC-130U
  1. Search drawing from free piston engine ->stelzer engine
    By Enginetuner in forum I.C. Engines
    Last Post: 12-20-2022, 11:13 PM
  2. videos from the stelzer piston engine
    Last Post: 12-20-2022, 11:06 PM
  3. Rocking piston engine
    Last Post: 12-12-2011, 10:33 PM
  4. Help with IC engine piston manufacturing
    By bob1112 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-18-2009, 06:45 AM
  5. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
