Originally Posted by
wizard
It is interesting that you want to machine the metal pieces first instead of going the wood router and the metallic machining. With no experience I would think it would be easier to ramp up wood machining on a router type machine. If you are starting out with zero experience I think you are going after a challenging metallic part.
As it appears in that rendering I don't see this item being easy to do on a 3 axis machine. Plus you would need to have the hole for the shaft bored some how. In fact I'd be tempted to bore and press in the shaft before machining the hub / axel support or what ever you call it. I'd also avoid cutting all the way through to reveal the pressed in axel.
Personally, as rendered, I don't see this as a practical part for an X3 sized mill but that is me. Depending upon which avenue you take you could be looking at a commercial mill in the $12,000 to $40,000 range. That just to profile the part and bore the pivot.
The responder above mentioned die casting, an industry I spent several years of my life in. That was zinc die cast which is slightly different than aluminum, in any event long term this might be a better path to follow if you expect volumes to ramp up. However even if volumes ramp you wouldn't want to die cast in house. The thing with a die casting is that you could then set up small mills to do a reaming operation for the pivot and a drill or boring operation to clean up for the pressed in shaft. You might not need CNC for that. The problem is die casting the part requires investment in a mold which you own. Since my die casting days where maybe 25 years ago I wouldn't want to even guess the cost of the die/mold. However get with the right supplier they should be able to estimate the cost closely and tell you how much the part will cost each. (Cost is roughly based on the weight of the metal). Plus a fixed setup charge, which can be huge when dealing with low volume parts. You would probably have to sell a lot of parts to pay for the mold, but I can't imagine you are getting each CNC machined axel assembly cheap these days. One other gotcha with die casting is trimming the part.
I could be wrong but I'm assuming you are paying a high price for the part and thus are looking to do it in house to lower costs. That is all well and good but it is often better to put capital else where. Buying a CNC machine will not give you an instant solution.
