Hey everyone, I posted back some time ago about the proximity switches and or lack thereof. On my machine, they are sporadic (faulting) and overall, I refuse to use them but that's not to say I wouldn't want them if I could get something better installed.
I have not crashed my machine since it's been in operation, having said that...I would like to have the Mach3 Soft Limits enabled from now despite my good fortunes.
Today, I am going to disable the home switches in the Mach3 config and position my table to a suitable location, set the Machine Cord. to 0 and apply my Soft Limits and be done with it.
That is until I upgrade the current proxy switches. Has anyone used these AutomationDirect Lever Switches? They look reasonably priced and appear to be resin filled giving them a waterproof design. Mounting won't be an issue with 3D printing and or machining possibilities.
AEM2G41Z11-3 | 1 N.O./1 N.C. limit switch - lever with 14mm nylon roller actuator
For now I will disable the Home Switches and manually input my WC Zero locations and use the Soft Limits until I get these wired up. I will be using the existing cables that are currently connected to the Proximity switches.
Regards all,
-Jason
