Can a semi-machined part be used as a Stock Definition? V26
I want to do some tooling operations in various orientations. I would like to have the first op use a "block" of material as the stock. The second operations I would like the stock to start as the "block" but with the first op machining operations material removed. For the third operation I would like the stock to start as the "block" but with the first two ops of machining operations material removed. Can this be done (easily)?
CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
