I am a surfboard shaper and looking to develop my business. I have found extremely helpful guides for CNC hot wire foam cutters online (www.8linx.com) The guide on that site is very simple and easy to understand for any skill level. However, I am going to need a cutter that cuts up to 12 or 13 feet. The majority of boards I'll make will most likely be anywhere from 5' - 8'. The guide on that website suggests anything 8' and over should switch over to a belt driven machine. I can't seem to find any good information on how to switch over.
I was also thinking of an alternative to the hot wire cutter for 1 reason. Surfboards have a piece of wood down the center of the board called a stringer. The hot wire is not going to cut throught that, so I'd have to cut each side of the board and then glue the stringer in last. I'd rather glue it and then cut it. Reading the forums I came across the suggestion to make a 3-axis cnc router to cut a surfboard. Does anyone have any tips or links to guides that may help or clarify this for me?
I appreciate your time.
Salvatore Amico
BlackDot Surfing
Owner
