Is anyone using this combination? I am just curious if the HRT-160 is a decent fit on the TM-1 or is it realy too big? If you have this combo and could post a couple of pics that would really help me decide.
Hercules
2008 TM-1, 2008 TL-3, 2009 TL-1, 2010 VF-2YT
What are the X, Y, Z travels on a TM1 (I am too lazy to go the the Haas website.).
You should be okay with that combination; I think you should be okay with a HRT210 on a TM1.
Z travel is 16".
You will be fine with the HRT160 and you probably could use the HRT210. I have several Super MiniMills equipped with HRT210s; these have a Z travel of 10 inches and the have the Z axis extension of 4 inches.
I recommend the HRT210 because it has a brake with a much higher holding torque than the 160.
I had a TM-1 with a HRT160B and it fit and worked perfectly. Just have to watch out for long tools in the toolchanger if your using the tailstock too.
http://i445.photobucket.com/albums/q...01Fixture1.jpg
http://i445.photobucket.com/albums/q...01Fixture2.jpg
What is the size of the T-slots in this 160?
The website just says theyre standard size. Do they mean standard 5/8 like a bridgeport?
Also, what is the smallest bolt circle that will fit on the table?
(Im trying to design a fixture to bolt on to an indexer we dont have yet )
The T-slot details are as follows:
Widths = .562" and .930"/.970"
Depths = .375" and .735"/.765"
They use standard 1/2-13 T-nuts
Using standard T-nuts, the smallest bolt circle is:
HRT160-3.92"
HRT210-4.37"
HRT310-6.00"
HRT450-9.84"
HRT600-9.84"
Thanks,
Ken Foulks
Thanks !
I was looking over the specifications for the HRT-210 and it looks to me like it projects almost 18" from the center table slot. I measured my TM-1P and I don't think it will clear the door with the table at Y0. The 160 should. I guess you could position it in the most rearward slot to get the clearance but then you only have 3" in Y left to the back side.
Anyone using one in the enclosed TM-1P?
I see Haas has the HRT series of tables available with the motor/gear box mounted on the back side. One of these would fit but they are more expensive and probably not as reliable.
Vern
