A couple of months ago I cut some cabinet parts and they came out all kinds of wrong. I went over everything on the machine after that. I took apart the z axis to grease. I ordered belts and several other things from cncrp/avid to get what I needed. I did not replace the belts since they seem fine so far.
I moved my router up a few inches to get rid of any chance that the leverage was an issue too. Then I realigned the cutter to the table. Replaced all the grease fittings with the newer ones that do not stick out also.
I've worked on several more things without issue. It only seems to happen when I use the entire bed and it's very random where it decides to do what it does. I do not think this is alignment or squaring. I'm at a lot on what to look for now though.
What's weird about it, to me, is that almost all cuts are perfect. The problem showed itself today on the first depth of cut I took on the drawers I was making. The first cut seemed to be about 1/8 inch off from where it should have been. But only on a few places. It doesn't makes sense to me because the rest of the cuts on that first one and the rest of Jon are on the right location. Since I do not have a way for the machine to correct itself while cutting if it did lose steps, then why would it?
Some pictures look perfect. They are, just so you see how weird it is. Others, specifically the curved one, started on the correct location and proceeded to cut off of where it was supposed to. Then the next layers all worked fine under that cut. Not in the same location but, in the right one! All the cuts are square though too. All the boxes fit together but, on the ones that didn't cut correctly, they look kind of not square. Only because one rabbit was lower than supposed to be. The curved parts on one are fine and not on the other. I also duplicated these in fusion and they are the same for each and the simulation looks perfect as well as the design itself does not have these features.
The gap in the last photo is just because I didn't push it all together yet. Just trying to show that it's taller than it should be.
Any idea what I should be looking at? Thanks, kind of makes me unmotivated to do anything because it doesn't come out the way I expect.
Sent from my SM-N960U using Tapatalk
