587,189 active members*
2,578 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Sprutcam 7 problem
Results 1 to 2 of 2
    Jun 2014
    1780
    Sprutcam 7 problem
    I have been using the "Transformation" function to do multiple operations in my multi part programs, everything worked fine until I tried to use it for tapping, there it doesnt work or I have a setting wrong etc,
    Path pilot doesnt like the code it outputs, it has an F0 in a line of code for each op for some reason??
    I like the Transformation op as I dont have to select the curves etc on each part, but I cant get it to work with the tapping op. I was wondering if any of you have had a similar issue?
    thanks
    mike sr
    Jun 2014
    1780
    Re: Sprutcam 7 problem
    I fiddled with this op most of the day today, even redrew the model to make sure the problem wasnt there.
    I get an error in line 189 g81 g83 caused by an f0 in line 189 of the program.
    I set up the tapping op using conventional methods (selecting all the holes) and it works just fine.
    All the other ops work using the transformation tab.
    I think I will call Tormach on this one, it may just be a path pilot anomaly.
    mike sr
  1. A Axis Problem - Mach3 or Sprutcam?
    By wwendorf in forum SprutCAM
    Last Post: 09-20-2013, 04:41 AM
  2. A Axis Problem - Mach3 or Sprutcam?
    By wwendorf in forum Mach Mill
    Last Post: 09-18-2013, 09:00 PM
  3. Sprutcam
    By ErnieD in forum SprutCAM
    Last Post: 10-05-2012, 08:43 AM
  4. Sprutcam Text Generator Problem
    By murphmoose in forum SprutCAM
    Last Post: 06-18-2012, 08:45 PM
  5. Sprutcam Text Generator Problem
    By murphmoose in forum Tormach Personal CNC Mill
    Last Post: 05-27-2012, 07:47 PM
