588,025 active members*
4,789 visitors online*
Results 1 to 6 of 6
    Aug 2012
    K-15 No Coolant Flow
    I could use some help.
    The coolant pump stopped on my 1995 K-15.
    When I manually press the button on the MS3 solenoid,
    the pump runs and coolant flows.
    What do I check next?
    Thanks in advance.
    Jul 2012
    did you check the relais?
    Aug 2012
    No. The book says it's RY8 but I don't know what it looks like or where it is.
    Jul 2012
    Ok but what Hyundai-kia machine model is a K 5....
    and which controler does it has
    Aug 2012
    Model KT 15
    Serial #KT15306
    Yasnac LX3
    Aug 2012
    Solved.
    Turned out to be the MS3 coolant solenoid.
  1. How to get flow in the tub
    By CaptainVee in forum Mass finishing equipment/media/strategies
    Last Post: 01-17-2012, 09:15 AM
  2. flow jet???
    By axkiker in forum Uncategorised MetalWorking Machines
    Last Post: 12-02-2010, 11:46 PM
  3. X DAC Under Flow
    By sidstover in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2008, 03:01 AM
  4. Flow
    By Haeusser in forum Waterjet General Topics
    Last Post: 03-13-2008, 02:04 PM
  5. Replies: 1
    Last Post: 12-28-2006, 05:20 PM
