587,322 active members*
3,354 visitors online*
Thread: CCM rails
Results 1 to 3 of 3
    Feb 2015
    113
    CCM rails
    Hello,
    Does anyone have tried the CCM rails for building CNC plasma ?! It seems suitable for that. According to the manufacturer
    CCM W45-15 linear module
    Positioning repeatability: <0.05MM
    Load capacity:*15KG
    Width: 40MM
    Pitch: 75MM (the linear travel distance is 75mm per one motor rotation, so if i used nema 23 motor with 1000rpm the speed is 1.25m/s)!!!
    Max length: 4*meters
    1) high accuracy
    2) customised length up to 4*meters
    3) anti-corrosion
    4) maintenance-free
    5) noiseless
    6) low vibration
    7) high reliability
    8) high durability
    9) flexible*add-ons
    10)*warranty up to*5 years
    According to this parameters is it suitable for plasma cnc ?!
    https://www.ccmrails.com
    http://www.mjunit.com/
    Can i use 3 units 2 for x axis and one for y axis ?!
    Sent from my ONEPLUS A3000 using Tapatalk
    Jul 2014
    67
    Re: CCM rails
    what is the difference between ccm rails and mjunit ? Seems both sell the same products..
    May 2015
    686
    Re: CCM rails
    You really need to add a 3:1 reduction ratio to get your motion back in the right range otherwise you will get a lot of jerky motion (I nearly made the same mistake as you but a couple of guys stopped me). The gear boxes will usually have a fair bit of backlash but its not hard to build a timing belt reduction that bolts onto the NEMA 23 mounting holes (which is what I did).
    Read my journey here https://forum.linuxcnc.org/30-cnc-ma...e?limitstart=0
    PS, I found the maximum speed I could get out of my cheap NEMA 23 was 750 rpm using hardware step generation from a Mesa 7i76e ethernet board and 20x microstepping. I doubt you'd get that speed out of a standard breakout board. (the Mesa board can do up to 10 Mhz). I had worked on max RPM of about 460 rpm based on my experience with an Arduino so I was very surprised!
    Rod Webster
    www.vehiclemods.net.au
  1. diy rails
    By Alaamomen9 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-14-2017, 06:32 PM
  2. What rails did you use?
    By jharvey407 in forum Linear and Rotary Motion
    Last Post: 02-28-2014, 07:27 PM
  3. NIB THK rails
    By lgalla in forum Linear and Rotary Motion
    Last Post: 02-24-2011, 09:11 PM
  4. Thomson Bars, V-Rails, or Linear Rails
    By Chuck_M in forum Linear and Rotary Motion
    Last Post: 12-18-2009, 09:39 AM
  5. Design of plasma table, high rails or low rails?
    By Apples in forum Waterjet General Topics
    Last Post: 12-18-2006, 09:21 PM
