Hey all.
So I am finally putting my foot down and pushing forward.
I have or just about have ( on their way ) 3 stepper motors from the Asian market rated at
1 x 6.3 amp 5.5 mH 3V 1250oz/in nema 34
2 x 7 amp 3mH 2.8V 1250oz.in nema 34
First one for the Z and the other 2 are for the X and Y axis.
I am throwing Rockford precision rolled screws at the machine ( 6.31 x .200 pitch ) and I also have 3 x Gecko 201 drivers.
I am also making my own floating preloaded nuts for each axis + one shot lube system to loosen things up - hah.
With a C1G BOB from cnc4pc + mach 3 software.
I all ready have a VFD and motor running on the mill.
I will be rewinding a microwave transformer for the 2 required voltages since 2 require 55V and the other at roughly 75V.
My most pressing issue right now is the connection of the stepper to the screws.
Do I or should I gear them down? I have yet to see a RF45 converted to CNC with a stepper motor, - most of the guys use servos, but this was far cheaper for me this way, FAR cheaper.......
its 1250 oz/in holding torque I guess, and any thing above 1000 PPS drops rather drastically, Like you would expect from any stepper torque to speed ratio.
Calculation force that I have using this fellows site http://graetech.com/index_files/Page736.htm
Yields me 2*pi*8.8 Nmeters / .005 ( pitch in meters ) = 11058 lbs force.
That would be at max torque and direct coupled to the lead screw.
Now That torque will never be 100% with the gecko drive as I understand. Some thing to do with the sine wave, making 1 phase 100% and the other at 70% at any one time - Is this correct?
I calculate 875 oz/in the best I can do. at 1:1
And then your friction you need to over come and other factors.
So if some one can reply with the above information and enlighten me I can then continue on and keep a detailed log of all my work, I will give credit to the guys who have helped me along this far - you know who you are.
Thanks every one!
