587,300 active members*
3,036 visitors online*
    Jan 2007
    6
    Ikegai FX25n spindle range shift
    Hi All;
    Does anyone know the M code to get the high-low clutch on a FX25 to change? I can get it to change using the manual controls but not in a program. A 1500 rpm speed will stay in high when given a 200 rpm command. The spindle will slow down to the commanded speed but, will stay in high range. I need a shift for the torque. I'm thinking an M code for the range shift? The control is a Fanuc 5T Thanks db
    Sep 2005
    767
    I'm not sure about the Ikegai, but the EIA standard M-codes for gear changes are M40 through M45. If you put one of these M-codes into your program and the Ikegai doesn't use it, the control will just stop on that block with the cycle start light on. You should then be able to reset and try another M-code.
    Jan 2007
    6
    Dan;
    I tried M40 to M45 no luck! The cycle start light comes on and stays on till I hit reset. Any other ones you can think of? Thanks db
    Dec 2008
    28
    Fx25N
    M38 -M39 will change the clutch Clamping
    Paul
  1. Ikegai FX20N lathe
    By gridley51 in forum Uncategorised MetalWorking Machines
    Last Post: 11-18-2007, 01:19 AM
  2. Ikegai TV-4 machine M06 not working.
    By Ashu in forum CNC Machining Centers
    Last Post: 09-26-2007, 03:47 PM
  3. Ikegai FX25n spindle range shift
    By Dee Bee in forum Uncategorised MetalWorking Machines
    Last Post: 07-07-2007, 10:35 PM
  4. How much does an Ikegai FT20U weigh?
    By protrxrptr17 in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2006, 02:39 AM
  5. Spindle speed range or lack of it!
    By creep_pea in forum Bridgeport / Hardinge Mills
    Last Post: 10-04-2006, 10:42 PM
