587,401 active members*
3,447 visitors online*
    Aug 2010
    6
    powersuppy replacement help...
    I'm looking for a solution for my Practical CNC problem.
    It seems the controller power supply is only putting out 7.7 volts (10.5 v when disconnected from motherboard) rather then the 48v its listed for.
    It has a Globtek gt sp-150-48 power supply installed.
    I cant seem to find this exact unit for sale and am wondering what a good replacement would be.
    Oct 2008
    406
    How many amps do you need? Keling had several different supplies that look pretty good.
    http://www.kelinginc.net/SwitchingPowerSupply.html
    Bob
    "Bad decisions make good stories."
    Dec 2003
    24223
    I believe the 150 stands for 150watts, which if is not very much.
    Jameco have a 48v 240watt model.
    http://www.jameco.com/webapp/wcs/sto...001_2094936_-1
    Personally I would look at a linear supply if this is for steppers or servo's, much more rugged and fixable, should it fail.
    Al.
    Albert E.
    Aug 2010
    6
    it looks like its actually a Mean Well part # for the identical unit.
    I found one near by and will let you guys know how it looks when it arrives.
    yes it runs steppers. 3 gekko drives.
  1. I need a replacement keyboard Key
    By donl517 in forum Fadal
    Last Post: 06-14-2007, 11:52 AM
  2. AhHa replacement help me
    By tony@med in forum Bridgeport / Hardinge Mills
    Last Post: 05-26-2007, 10:37 PM
  3. Vmc 20 Inverter Replacement
    By 340 in forum Fadal
    Last Post: 02-23-2007, 10:37 PM
  4. fan replacement on cnc kit
    By krymis in forum Charter Oak Automation Support Forum
    Last Post: 01-27-2007, 03:45 PM
  5. vdu replacement
    By bbrreid in forum CNC Machine Related Electronics
    Last Post: 09-02-2004, 09:24 PM
