587,940 active members*
3,208 visitors online*
Results 1 to 6 of 6
    robodrill advice,
    hi guys,
    I got a fanuc Robodrill with 16M control which has a few problems, my main concern is the batteries for the axis ref positions keep going flat, a new set lasts 3 weeks then I get the alarms and do the procedure for setting the refs again,
    what can be draining them so fast?
    appreciate any help,
    chris.
    Nov 2012
    1272
    Re: robodrill advice,
    Conductive dirt/dust/residue/corrosion on the circuit board? A leaking capacitor? Next time you change the battery, try measuring the resistance across the battery socket.
    There are more reasons than a dead battery as to why you have lost the zero position. Next time you get the alarm check the diagnostic bits to determine exactly why you lost zero.
    Attached Files Attached Files
    I dont have parameter 310, it goes from 301 straight to 1001, is there an alternative to this sheet to cover my age of machine?
    Its not a parameter. its under dianostic
    it was a bad X encoder that was taking the juice,
    chris.
  1. robodrill advice,
    By robodrillman in forum Fanuc
    Last Post: 03-11-2020, 01:00 AM
  2. robodrill I/O advice,
    Last Post: 01-16-2020, 11:04 PM
  3. New Fanuc Robodrill or 7000 hour robodrill with all the bells and 4th axis?
    By The_R1_Kid in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2018, 01:26 PM
  4. Robodrill HSM
    By dniemela in forum CNC Machining Centers
    Last Post: 01-05-2012, 04:42 AM
