587,098 active members*
6,113 visitors online*
Results 1 to 3 of 3
    May 2008
    667
    Grizzly lathe chuck
    Hi.
    I have a Grizzly lathe model G9972Z
    This is a great lathe but I have one problem.
    I can't remove the 3 jaws chuck. I've tried many times but never had success.
    I unscrew the two small clamps from the back of the chuck but there is no more I can do.
    Is anybody have some ideas to unscrew the chuck.
    I post some pictures of how they do it in the manual.
    Thanks for any help.
    Jeff
    Nov 2009
    4415
    Have you tried chucking a bar in the chuck after the screws are loosened? Then you should be able to wiggle it a bit and hopefully it will release. You could also extend the bar thru the spindle and hit the bar with a hammer from the headstock end driving the chuck towards the tailstock, be sure to put a board under the chuck. How long has the chuck been installed? If both of the above ideas dont work I would resort to dry ice and freeze the chuck thouroughly and let it warm up and see if it broke the bond. Failing that I would introduce heat but then seals might be sacrificed. Heat would be a last resort.
    Nov 2009
    4415
    Sorry, I just realized it was a threaded chuck. Are the threads left hand or right hand? Again chuck a bar sideways so it would lay against the ways (actually on a board on the ways) engage the lathe so the motor unscrews the chuck. Use a low gear and just bump the power. Or just take a deep cut in reverse with those screws already loosened :-)
  1. Grizzly 110 Volt lathe
    By Johns tool room in forum Phase Converters
    Last Post: 08-23-2011, 03:17 AM
  2. Comments on a Grizzly lathe
    By charliechaz1 in forum MetalWork Discussion
    Last Post: 08-10-2009, 04:03 AM
  3. Grizzly lathe with VFD
    By Willbird in forum Phase Converters
    Last Post: 02-06-2008, 03:02 AM
  4. Any opinions on the Grizzly g4016 lathe or other Grizzly lathes?
    By DublD in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2006, 07:23 PM
  5. New Grizzly Lathe what else do I need?
    By CNC Brute in forum Uncategorised MetalWorking Machines
    Last Post: 03-04-2004, 01:03 AM
