Re: Huayang VFD GT series Auto tuning
Originally Posted by
mactec54
If these are the only Parameters you set then you are running in V/F mode, which won't be a problem for the OP as well once he set his main Parameters
If your VFD Drive is matching then you won't have a problem as well, but you do need to set more Parameters than that or you will be just running in V/F mode, which does not have any problem doing this in auto tune, it is when you use it in Vector mode that the VFD Drive is not working correct
Mactec54,
I'm unfamiliar with the "Speed Control Mode" between V/F and Vector Control... what are the advantages of using Vector Control?
It also looks like its P0.00 = (1 or 2) not sure which I would choose... and if that is the only setting needing to be change to set it up.
Adam,
Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
