Re: Problems zeroing Matsuura MC-500V
I'm resurrecting this old thread because I'm having the same problem as the ccbrass, except it's in the Y axis. My machine is a 1985 Matsuura MC-500V2S with a Yasnac MX2 control. The machine was working OK until I let it sit for a couple of years. When I brought it out of hibernation the table movement in the Y axis was very jerky. We removed the brushes on the Y servo motor and instead of the normal carbon dust we found an oily sludge. Apparently oil had found it's way into the servo motor but fortunately the tachometer section had stayed clean. The servo was removed, disassembled, cleaned, reassembled and put back on the machine. Now the table moves smoothly but I can't get it to zero out in the home position. I just get alarm code 202, "overtravel Y". The limit switches check out good. Both the X and Z axis's zero out normal. We also tried swapping the X and Y servo boards but the result was the same.
I'm thinking that this might be a software issue that needs to be reset but I have no information about this. Anybody know?
PHD is an acronym for a machine operator who can only load parts and hit the cycle start button. Push Here Dummy.
