587,611 active members*
4,121 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > vfd help over a year now please
Results 1 to 7 of 7
    Mar 2016
    42
    hello all i'm hoping someone can really give me a helping hand .i've had my vfd for well close to two years and i still don't understand it .yes i've been using it but when i start a job i have to start/stop adjust etc etc. id like the software to do it.
    long story short after buying 4/5 control boards i found one i'm liking small cheap standalone but now back to the same problem ( i have no clue about it or the manual ive been trying to learn research (i'm hopeless)
    the vfd i have is a kinda 320 series 2.2kw .the now new board is the cheap ddcsv1.1 i also have xhc 4 axis mach 3 motion card no matter what. i think i need 3 small wires but no clue where they go.can someone help?
    i will attach both pdf thanks in advance
    Mar 2016
    42
    Re: vfd help over a year now please
    heres a pic of where wiring would go.. anyone?
    Attached Thumbnails Attached Thumbnails 24331511_10159549213520262_228699765_n.jpg
    35538
    Here's some guesses, but I can't say for sure if this is correct.
    See page 20 of the controller manual.
    I believe that VSO is the analog output, and should be connected to the VI terminal on the VFD.
    ACM is the analog ground, but I don't know if it should go to the GND below the VSO terminal. I think it does.
    The M3/M5 terminal on the controller should control a relay for on/off. Page 21 shows a wiring example. The relay should have a NO and Common, which would connect to the MI1 and DCM terminals on the VFD. Set parameter F5-00 =1
    Mar 2016
    42
    Quote Originally Posted by transformer82 View Post
    ok i still think im wrong but this is what i get for all of this m3= forward connected to mi1 and dcm?
    and vso would be set to +10v and amc?
    Mar 2016
    42
    thanks ger21 i think i see what your saying. vi would be 0-10v for speed?
    do i need a relay? resistor?
    35538
    Yes, you use a relay for the MI1-DCM terminals.
    I don't know about resistors. I'm not an electronics expert.
    Mar 2016
    42
    do you what kind of relay?
  1. the three year poof!
    By howecnc in forum Tormach Personal CNC Mill
    Last Post: 04-23-2011, 04:47 PM
  2. journeyman 325 year
    By MadPickinSkills in forum Tree
    Last Post: 09-23-2010, 09:37 PM
  3. MV jr around 86 year
    By andyhol in forum Mori Seiki Mills
    Last Post: 02-26-2010, 11:23 PM
  4. New Year, New Job
    By metalfab in forum Community Club House
    Last Post: 12-17-2005, 05:17 PM
  5. New Year, New Job
    Last Post: 12-17-2005, 06:40 AM
