588,086 active members*
4,597 visitors online*
Results 1 to 3 of 3
    Nov 2013
    3
    Spindle seize
    We have a new VF4-SS and the spindle bearings just seized up. Air line pressure was a little high around 110 psi. The auto lube system appeared to be operating normally, sending small oils drips every 20 min. Could the higher air pressure cause the bearings to fail?
    Re: Spindle seize
    Quote Originally Posted by jdmech2013 View Post
    Any alarm code on the spindle driver?
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Nov 2013
    3
    Quote Originally Posted by cncmakers001 View Post
    No alarm code was present.
  1. Replies: 3
    Last Post: 10-19-2018, 05:12 PM
  2. Seize the key so that laser cutting machine has a better fate
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-20-2014, 10:11 AM
  3. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
  4. Replies: 2
    Last Post: 03-09-2011, 07:00 PM
