587,534 active members*
3,512 visitors online*
    Nov 2010
    Timer-interrupt-frequency?
    What is timer-interrupt-frequency(steps per second) of this 6A unipolar driver.
    Dec 2003
    24220
    From the design of the output and the voltage supply, I would hazzard a guess the max. step rate is not going to be that high at all, it is intended as just a manual push button motor stepper.
    Al.
    Albert E.
    Jul 2008
    411
    The maximum step rate given by the internal setting on that circuit is about 50Hz, however the circuit itself will be ok to much higher than that.
    The achievable step rate is limited by the motor. If you are planning to use the 24v motor listed in your other thread your maximum step rate will be probably around 200Hz, about 4 revs/sec (its a 48step motor)
    If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
    Mar 2007
    2083
    are you intending to use the on board oscillator / step circuit ?
    the output frequency = 1/1.2 RC
    with the values for C5 =1 uF , R1= 10K and VR1=1M as in the circuit , the output will be from about 1 to 80 hz ( = steps per second )
    the actual frequency depends on the switching point of your 4093 ic and the value of C5 ( could be 0.5uF to 2 uF ( -50% +100%))
    changing C5 from 1uF to 0.1 uF will give you around 10Hz to 800 Hz
    John
  1. Feed interrupt needed, I think??
    By thedoctor in forum DNC Problems and Solutions
    Last Post: 07-17-2008, 02:03 PM
  2. No Interrupt on vf2 2000
    By tecko in forum Haas Mills
    Last Post: 01-26-2008, 01:59 AM
  3. E-stop, Interrupt The 110v Ac Or 28v Dc?
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 02-06-2007, 03:49 PM
  4. inputio interrupt driven?
    By howling60 in forum CamSoft Products
    Last Post: 02-10-2006, 08:38 PM
  5. Optical Switch w/Interrupt mechanism
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 11-10-2004, 03:51 PM
