587,997 active members*
2,056 visitors online*
IndustryArena Forum > CNC Electronics > PIC Programing / Design > isolated DAC. PWM ( 20khz ) to analog 0-10Volt
Results 1 to 2 of 2
    Jan 2007
    93
    I have found this shematics .
    For R6 and R7 i have put 33kohm resisitors and i get 2.5 Volt output when there is no signal.
    Anyone knows calculation for this circuit?
    Feb 2007
    968
    Re: isolated DAC. PWM ( 20khz ) to analog 0-10Volt
    What you want is when there is no input, the output is zero.
    The 1st amp is an inverting amp. so then there is no input, the - input is pulled high, making the output low.
    I would increase R4 to give the inverting buffer (1st amp) a very high gain. Make R4 1Meg and see the result.
    R6 and R7 are ok at 33k or 100k since they are just a voltage divider.
    Larry
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
  1. Isolated break-out board
    By yassser in forum Computers / Desktops / Networking
    Last Post: 03-06-2012, 04:43 PM
  2. low-side isolated current sensing ? (0-10 A)
    By andy55 in forum CNC Machine Related Electronics
    Last Post: 04-23-2009, 05:20 AM
  3. Opto-isolated BOB design
    By LZ1TWB in forum CNC Machine Related Electronics
    Last Post: 08-30-2008, 10:50 AM
  4. buffered vs Opto Isolated
    By miljnor in forum CNC Machine Related Electronics
    Last Post: 02-18-2006, 12:14 AM
  5. I need to isolated the problem.
    By on7tim7 in forum Mach Mill
    Last Post: 12-04-2005, 12:01 AM
