587,081 active members*
2,518 visitors online*
IndustryArena Forum > Engraving / Art Design Software > Jewelry Design Software > Vectric VCarve Pro - Embossing Dies - V-Carve toolpath problem
Results 1 to 2 of 2
    Oct 2012
    9
    Question Vectric VCarve Pro - Embossing Dies - V-Carve toolpath problem
    I make Embossing dies out of 7 mm Magnesium Alloy. They are not bigger than 150mm x 100mm.
    For my roughening, I use a 3 mm router bit. 5 mm deep with an offset of 0.4 mm.
    And for finishing I use a 6 mm x 60 Deg V-bit 1.5 mm deep. To save time, I use the "Use Flat Area Clearance tool" function and add my 3 mm bit to it.
    This will create "chamfered edges" on the artwork. Attachment 185784
    My problem is that I have a border around the artwork that I'm machining, now the finishing tool goes and machines the border as well. (I cut the die out off the stock using Profile toolpath)
    I want to know if there is any other way to prevent it from machining the border.
    See Picture Attachment 185780 V-Bit is the Purple tool path.Attachment 185782
    This extra toolpath on the border is wasting time, how can I remove it without editing my cnc* file.
    or
    is there any other similar software that will help?
    Mar 2017
    Re: Vectric VCarve Pro - Embossing Dies - V-Carve toolpath problem
    HI Sir,
    Have you found a solution to this problem using vcarve?
  1. Need CNC work on embossing dies
    By Jim27 in forum North America RFQ's
    Last Post: 02-27-2013, 07:06 PM
  2. Z axis in Vectric V carve pro.
    By alanstclair in forum Uncategorised CAM Discussion
    Last Post: 07-09-2012, 02:30 AM
  3. Replies: 5
    Last Post: 03-18-2012, 09:17 PM
  4. Anybody here use Vectric VCarve?
    By mmcguire in forum Musical Instrument Design and Construction
    Last Post: 05-26-2010, 09:10 PM
  5. Paper embossing dies
    By salvaCNC in forum Diemaking / Diecutting
    Last Post: 03-20-2008, 06:19 AM
