Ive just checked the gibs after over a years use since the last adjustment - I guess around 300-400 hours running.
Very pleased with the wear situation - gibs only needed 1/2 - 1 turn. I use the 'step reverse' method where you set the step to fine (mine is left on metric 0.01mm ( or about 0.0005" )) and with a dial indicator click an axis one way - then change direction. I allow a max of 'one lost click' before movement begins in the other direction. My Z and X had no lost movement so I began to tighten the gib - a half turn began to introduce enough drag to begin the 'lost movement click' The Y had one lost click at fully out (less slideway wear here) and no lost click in the middle of the Y travel - again I tightened up less than a turn before lost motion increased. I double checked the actual slideways clearance with a dial indicator set to measure between the sliding surfaces and then applying a heavy racking load...and I got - apart from spring that returns, the permant shift or clearance was not more than 0.001" Very pleased!
I exposed and cleaned the ways first - they looked in good shape. I always operate the oil plunger at the start of each day - plus I manually coat the slideways and screws from time to time in case the central system does not evenly lubricate. This may be in part why I have little wear - but results in quite a bit of lube/tramp oil floating on the coolant in the tank. I just thought of an easy way to remove it today - probably in common use but in case others have not heard of it.....
Spread a clean rag out on the surface of the coolant - leave for a short while, pull the rag out in a way that catchs the oil and quickly dump it before too much tramp oil escapes. Repeat.
