I am trouble shooting my 4020 and have no experience with Fadals.
I suspect the Z amp card might be faulty and have tried using the Y amp for the Z motor. It works fairly ok. In order to see if I can get rid of e-stop and do a cold start I would need to use the A axis amp for the Z motor, but this looks different from the X,Y and Z amps. Will it work or will I destroy something?
I am also having problems with the Z control card. It will not blink unless I remove a few other cards from the cage. Could be voltage as I only get 4,84VDC to the cage. The A axis card works better, but even after setting the J4 jumper to Z each 0,0001 pulse displays as 0,001. Not sure if it moves the same as the display or if the display is showing 10 times the pulse.
Andy
