587,908 active members*
3,845 visitors online*
Results 1 to 3 of 3
    Oct 2018
    3
    Anilam 1100 handwheel?
    I recently purchased an old Millport Rhino mill with a 3-axis Anilam 1100 controller. If I had realized that all involved companies would be out of business and manuals impossible to find I would have looked elsewhere...but I digress.
    There's no manual control of the Z-axis outside of jog functionality. But, the 1100 accepts a handwheel. There's even a port in the back: it looks like a 25-pin setup, but it only has 4 exposed pins.
    I know from the programming manual that came with the machine that the axis controlled by the handwheel is set through the controller and not the handwheel itself. My understanding from this thread https://www.practicalmachinist.com/v...l-test-293705/ is that the pins should be Power, Ground, A, and B.
    I doubt I'll ever find an original handwheel for this sort of thing. So I'm wondering: could I get something like https://www.ebay.com/itm/Universal-C...r/312259374772 and only attach the Power, Ground, A (not A-bar) and B (not B-bar) pins? I have no idea how "universal" the quadrature logic is, and if the signals sent by such a handwheel would be compatible. I'd just love to know if this idea would work or not before I blow $100 on the wheel. There is supposedly an actual hardware manual for the 1100 controller that has details about the handwheel, but I can't find it online anywhere (and it obviously didn't come with the machine, that would be too useful).
    So yeah -- anyone have any advice on this thing? I just want a Z-axis I can reasonably control.
    Mar 2011
    67
    Re: Anilam 1100 handwheel?
    You are spot on as far as it is a 5v TTL input. Just have to dig up an Anilam diagram that shows hookups.
    Dec 2013
    5716
    You could use one of these, same encoder without the box, cable, and switches. It will work fine with the Anilam as will the one you linked to.
    https://www.ebay.com/itm/Silver-6-Te...bQd:rk:18:pf:0
    Jim Dawson
    Sandy, Oregon, USA
  1. Anilam 3300M Handwheel Axis Problem
    By mikevee in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-18-2016, 01:51 AM
  2. Anilam 1100
    By dmealer in forum EdgeCam
    Last Post: 01-20-2012, 06:52 PM
  3. Anilam 1100
    By boatman321 in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2011, 01:19 PM
  4. Anilam 1100
    By english bob in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2008, 04:12 AM
  5. anilam 1100
    By tmt_92021 in forum MetalWork Discussion
    Last Post: 07-09-2006, 05:28 PM
